Old 03-31-2006, 12:04 PM
XFIREZ28 XFIREZ28 is offline
1991 tranny install
1991 s10,2.8, 5 speed finally had to replace clutch at 297000. now tranny want go all the way in bout 1 1/2 - 2 in. shy. mite be splines not lined up or not hitting piliot bushing rite.what do yall think. any help would be lovely. thanks
Old 04-02-2006, 08:56 AM
eti engineer's Avatar
eti engineer eti engineer is offline
Re: 1991 tranny install
Get yourself a clutch alignment tool if you don't already have one. They make universal types. If that clutch disc is not centered with the pilot bearing recess, you will never get the thing back in. If you have trouble after this, check your guide pins, etc. Make sure all is lining up.
Did you trial fit the clutch disc on the tranny input shaft first to ensure it was the right one? I have seen clutches with different numbers of splines in the same type of vehicle, same year. Mid-year production changes...
One thing you should also do is make sure the clutch disc can move freely on the input shaft splines. It doesn't hurt to put a small amount of lubricant on the splines to ensure this, but not a lot. You don't want it spinning out into the clutch lining. If the disc cannot move freely on the splines, you will have a binding clutch.
Hope this helps..
eti engineer
Old 04-02-2006, 09:14 AM
thanks eti, i will take it back down and start over!!!:
Old 04-02-2006, 09:20 AM
Not a problem. This is the voice of experience speaking as I have done several of these and experienced about every problem you can think of. Another thing, make sure the clutch disc is facing the right way -- not 180 degrees out!! I helped a friend once who had installed his clutch disc backwards and it took a while to figure it out
Have a great one, whatever it is...
eti engineer
SAVE TIME AND TAX DOLLARS -- EXECUTE THE PERP, NOT THE WARRANT...
10 pm. my yard. your cat. my gun sights. (keep 'em home!!!)
