Old 07-10-2002, 11:40 AM
Bustamon's Avatar
Bustamon Bustamon is offline
Shaving antenna affect CD Player?
I'm about to take my Civic to the shop to have my door trim and antenna shaved and I need to know if shaving my antenna will affect my audio system in any way. I'm pretty sure my radio reception will be fucked up but will it affect my CD player? :help:
Old 07-10-2002, 12:23 PM
Bustamon's Avatar
Need help! This is a very important question.:alien:
Old 07-10-2002, 10:29 PM
luti luti is offline
Send a message via AIM to luti
I have no experience in this, but I see no reason why it would in any way effect your CD or tape deck. Yeah your radio reception might blow, but otherwise it should be normal...
T3/T04E turbocharged ricer.
Old 07-10-2002, 10:34 PM
93speed's Avatar
93speed 93speed is offline
I'm 99% sure it won't affect your CD PLAYER. It will, most likely, affect your reception. For a little test, go unplug your antenna from your CD player and see what it does and what stations you can pick up. If you go get one of the k-mart universal ones and put it somewhere like in your back window, but hide it good, you should get your fair share of stations. Or you could always invest in satellite radio
Old 07-11-2002, 12:00 AM
colechaney colechaney is offline
Send a message via ICQ to colechaney
Your reception will blow, but it won't affect your cd/mp3/tape. Your HU is reading information off of whats in it. The antenna only affects the radio.
"You never heard of a mind as perverted as mine." -Eminem
Old 07-11-2002, 09:42 AM
Bustamon's Avatar
Thanks guys!
Old 07-11-2002, 02:42 PM
diesel_uk diesel_uk is offline
hello mate.Your headunit will not suffer apaprt fromy our radio singal.Most of your singal ( i take it you guys there are on f.m. too) will be ok some wont your am/mw reception will be none/kaput nill zero so if you can live without it then fine .if you listent o radio then i would install a "Indoor" ariel.They are common and can be loacted at shops /retailers in your country.All you have to do is "GROUND" yor ariel and you can do that in your car.A simple test would be cut a lengh of cable ( single flexible core/ mutli strande) run it along yuor fire wall or along any lengh of your car that is not visible.If you can live with the reception of the cable which of corse you will be plugging into your ariel socket at the back of you headunit. then thats fine as what you hear is what you will begetting. aNOTHER OPTION IS TO INSTALL A !"BEE STING ARIEL" which looks find i think an dwould suit most hatchbacks and saloons.My thought is with the first option which is to fit a indoor amplified arieal which youi can mount to the inside of your windscreen.Let us know how you get along mate .
[IMG]://www.webphotos.com/viewphoto.asp?mi=1&smi=1&a=75015&p=1638698[/IMG]
My advice is worth every penny you paid for.
Old 07-11-2002, 10:36 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
it won't affect CD playback unless your CD player ground is crappy, and it is drawing the ground from the antenna ground
Old 07-12-2002, 12:45 AM
Paul they isolate the ground as to cause no interfeace. so that kills your thoery.Sorry mate
Old 07-12-2002, 09:10 AM
Audio Guy
unfortunately, on all too many cars the antenna ground is NOT isolated
Old 07-12-2002, 09:40 AM
Sorry Paul, Did not want to sound clever i install lots of stereos and most in this country are isolated.Mabe its direrent in the states.If so sorry mate was trying to help.
Old 07-12-2002, 04:37 PM
Audio Guy
they used to all be grounded .... maybe I should measure a few from the newer cars to see. It used to be a big source of noise when I first started installing (like 20+ years ago - before CD players), maybe they have wised up a little.
Old 07-14-2002, 11:38 PM
quartz quartz is offline
Send a message via AIM to quartz
In my girlfriends 240sx the cd player would not come on unless the antenna was plugged into the back. Im guessing the cd player used it as a ground. But you may have that problem if you disconnect it
