okokok... CAMSHAFTS.
Well, I was thumbing through my stack-o-maro catalogs, and was eyeballing the cams/lifter/rockers pretty good, and thought immediately "WTF?"
So I now ask you humbly... what in the hell is the difference between Roller Cams, Hydrolic Cams, Roller rockers and whatever the other ones are called, etc? My maro has the aluminum roller rockers in it, but aside from exactly what I just said, that means nothing to me. Honestly, I was thinking that while I have my baby splayed all over my garage, why not put a new cam in so that at least I know what the hell it is. I was looking at the Lunati Voodoo Cams - hydraulic - and didn't know if you can switch between the two, what the real differences are, etc. Can you fellas enlighten me??? |
Re: okokok... CAMSHAFTS.
roller rocker arms have a rolller tips and trunions(thinks thats what there called) they look like this
![]() , they create less firction and more power and stamped steel rocker arm looks like this ![]() if you want roller lifter i suggest you select rollerized hydraulic lifter not just roller lifters, they are more streetable. a roller lifter looks like this, yet again it creates more power ![]() and a stock hydraulic lifter looks like this ![]() Hope i was some help
Formerly Blownalcoholboy 1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi) Best ET 1/4: 8.35 @ 170mph (275 drag radial) Best ET 1/8: 5.44 @ 132mph (275 drag radial) Best 60': 1.31 on the back tires (275 drag radial) AF User Rules/Guidelines http://www.automotiveforums.com/vbul...uidelines.html |
btw run a hydraulic roller lifter cam, i think it would be good
dont forget flat tappet.
92 z28 camaro 5.7 TPI current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
1. 92, what the fuck is tappet?
2. Babs, your pic on the rollerized hydrolic lifter ain't working. And yes you helped. |
And oh yeah... I have the roller rockers like the gold ones you posted. Except they're blue and they have "J 1.7" stamped on them. What the hell does that mean???
a tappet is the part of the rocker that hits the valve stem. I would try to go with a kit if your going to upgrade. dont want to be bending rods or anything like that.
ASE Master Certified before the age of 20 Current Cars: 2001 Chevy Silverado 1500 Z71 5.3L 1996 Acura Integra LS B18 1.8L Past Cars: 1990 Buick Estate Wagon 5.0L 1987 Chevy S10 2.5L Tec Four 1995 Pontiac Grand Am 2.3 Quad 4 1996 Jeep Grand Cherokee Limited 5.2L AWD 1991 Ford Tempo L 2.3L 1992 Buick LeSabre 3.8L 1997 Buick Century 3.1L 1996 Lumina APV GT 3.4L 2006 Ford Escape 3.0L XLT |
that would be the ratio(1.7) btw a hydraulic roller lifter looks like this
