Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Suspension
Suspension setups, shocks, springs, tires, handling.
Old 08-13-2001, 12:19 AM
ty423's Avatar
ty423 ty423 is offline
Send a message via AIM to ty423
Rim and Tire Size for P11
I am rolling on some 18x7.5 rims with 225/40ZR18 and was wondering if you guys think it is too big...I totally feel the power being robbed by the size and weight...and also on the brakes....I want to get lighter rims or maybe go smaller...like 17"
Old 08-13-2001, 01:16 AM
kenchan's Avatar
kenchan kenchan is offline
imo 18's are too big for these compacts. sure they look great, but the tire profile is too little for street. you should be using a 35 profile tire, on your 18s. ...theyre like rubber bands. hehe
wheel weight does make a HUGE difference coming off the line....especially for AT drivers. if you want faster acceleration, you might wanna change gear ratios by going to a smaller than stock circumference tire setup with lighter wheels.
1998 Prelude SS - TEIN HA with upper pillows, SSR Integrals 17x7 with SP8000 (215/45), GReddy Evo catback, Iceman Comp Intake, DC Sports header, Apexi VAFC, ZEX 55 shot with bottle heater, NOS blanket, Factory Body Kit, Spoon F/R tower bars, JDM Foglamps, Carbon Fiber trim, Razo pedals &knobs, Fiamm Dual air horn
Future Mods: Lighten car, 2nd 10lbs nitrous bottle would be nice too.
2001 G20 P11 AT- TEIN NA, TRM Snipers 17x7 with Potenza RE910 (215/45), Arospeed Dual-outlet Muffler, K&N Drop-in Airfilter, WW Front Lip, Nakamichi MB75 1DIN 6CD Changer/Receiver, FIAMM Dual Air horns, Levoc Pedals, PIAA (H4 Superwhite H3 Ion Crystal, 168 SuperWhite)
2002 WRX MT- TEIN HA's with upper pillow mounts, 1000Miglia HT3 17x7 with sumitomo HTR+ 225/45/17, painted side skirts, Cusco front & rear strut bar, Whiteline rear swaybar, aluminum endlinks, Blitz NUR Catback, HKS seq. BOV, factory front lip, rear valance, Kartboy short shifter and bushings.
Future mods: dressup wheels with Potenza S03 225/45/17 tires, TurboXS UTec, maybe an uppipe. by then, it'll be fast enough.
fiamm dual air horns.
Old 08-13-2001, 01:55 AM
primera man's Avatar
"P-Man"
18x7.5 seems big... but what offset are they ??
If they are to heavy and you want to change i'd either go 18x7 with a 42mm offset or 17's the same size.
View All My Models Here.
Old 08-13-2001, 03:02 AM
ty423's Avatar
+43 offset
Old 08-13-2001, 07:39 AM
b-b00gie's Avatar
b-b00gie b-b00gie is offline
Banned
Send a message via AIM to b-b00gie
Ty,
I have 18x7 +43 on 225/40/18. that tire size is actually oversized. .8" to be exact, so almost a whole inch.
I'm about to switch to some 18x7.5's soon. Probably gonna go with 225/35/18 this time which is the exact diameter as stock.
I orginally had 215/35/18, WAY too small...
About the weight issue, I wouldnt switch to a smaller wheel, it really makes no difference! Here's why...
Sport Compact Car did a test (I can look up the issue tonight). They compared the same model wheels in three sizes, 16, 17, 18" They all weighed in within 1lb or less than each other.
Of course the 16 and 17" will be lighter compared to 18, but you have more weight in the tires/air in the smaller ones! This is seriously the biggest myth there is!
I would just go to the correct tire size (225/35/18) or switch to a lighter wheel if you want (I think you have those 3pc 5Zigens? heavy!! I have 3pc too)
I wouldnt go to 17" to save weight, you wont save any in the long run becuase the tires are bigger and heavier and need more air...
Old 08-13-2001, 07:46 AM
Anthony Anthony is offline
Surely rubber is lighter than alloy though?
And I think the weight of the air in your tires is somewhat negligable compared to the weight of the alloys and the tires
Owner of Primeraweb, and a 1997 Nissan Primera SRi driver
Old 08-13-2001, 07:49 AM
b-b00gie's Avatar
Banned
Difference between a 17" and 18" alloy wheel of the same model is about 1 or 2 lbs less. Add the extra rubber and air and you are right back to the same weight.
This article was in Sport Compact Car and was run to clear up this life long myth...
I'll find the magazine tonight so you non-believers can reference it
Old 08-13-2001, 09:35 PM
ty423's Avatar
thanks for the info b-boogie...I never had thought about that...
Old 08-13-2001, 11:05 PM
b-b00gie's Avatar
Banned
the article was in January 2001 Sport Compact Car...
Old 08-28-2001, 04:05 AM
TeamNissan TeamNissan is offline
Send a message via ICQ to TeamNissan Send a message via MSN to TeamNissan
Talking Tire size
I drive with 215/35 - 18 on a car which is lowered 110mm and that is no problem! :frog:
/CEJ
Old 08-28-2001, 04:15 AM
maybe there is a little picture now! :o)
NISSAN RULES...........
http://www.nissanklubben.dk
Old 08-31-2001, 09:09 PM
cas8_1999's Avatar
cas8_1999 cas8_1999 is offline
Send a message via AIM to cas8_1999 Send a message via Yahoo to cas8_1999
to team nissan what rim do you have style and name? if you dont mind tires and rims how much did you spend
(VXION)PEOPLE ARE IN AWE TO WHAT THEY SEE WHEN THEY SEE YOU (AW 2 DA VI SION)
Old 09-03-2001, 04:41 AM
It's a rim called Design 1150 it's made by Avelini
I payed 11.000 DKr (1350USD) for rims and tires Falken FK452(New model) 215/35x18
