Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-30-2006, 09:38 PM
space-monkey2 space-monkey2 is offline
Banned
Weird Problems.....
OK so my engine was fishing for an idle after I replaced my stock turbo, with a stock turbo lol. But when the weird Idle fishing started I decided to take off my Throttle body and clean it and also replace my spark plugs. After that was done I cleaned out my engine (BADDD IDEA AGIAN I THINK) I used degreeser and a pressure washer at a car wash.... well now like a couple days later its idling at like uhhhh 3k rms! and I decided to replace my Idle Control Valve, and the car did ok for about 3 minutes then did it agian.... and ontop of it all when its idleing high im getitng like no boost. My gauge is saying 10 psi but you can tell its not there at all. Any ideas guys? I dont want to take this one to a professional thats expencive. If anyone lives around the texas panhandle or dalllas and wants to take a trip up here id pay for some shit, but throw ideas im all ears.
Old 03-30-2006, 09:50 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: Weird Problems.....
so basically your car is idling high?
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 03-30-2006, 09:57 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Check for a boost leak that could cause problems ith idle. You say you have 10 psi at ide? You should have more like 10 psi of vacuum at idle.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
blk_srt's Avatar
actually idle should be ~15in/hg depending on elevation. probably a boost leak, definatly air getting in somewhere where it shouldnt be
Mods:
Old 03-30-2006, 09:58 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Sounds like a possible boost leak... Pressure test your system.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 03-31-2006, 07:31 AM
Banned
No i have -25 vac at idle, it goes up to 10 psi when im driving, buttt my stock gauge goes up slower than the aftermarket one, like only in 5th gear will it go all the way to the + sign. But how do I do a boost leak, or is there a way to find a map of my vac hoses so I can make sure they are done correctly?
Old 03-31-2006, 08:35 AM
SLoe's Avatar
SLoe SLoe is offline
Stock gauge=crap. Pay no attention to it. Where is your aftermarket sourced from? boost leak tester.....search this site, or go www.vfaq.com.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 03-31-2006, 12:07 PM
blk_srt's Avatar
holy shit, you should idle at 25in/hg unless you were at an extremely high elevation or you had some major restrications on air flow
Mods:
