Old 03-30-2006, 04:35 PM
YoungMalibu YoungMalibu is offline
HELP with Codes
I did that paper clip test and it came back with
12 , 15 , 34 somebody please help me with this..
I have a 3.1 Euro Lumina, been having wierd problems, when i let the car sit overnight, i start it up i drive it for about 5 mins NO problems, drives like a champ, well, when i run it for a minute it has this hesistation until i get in the upper rpms, i mean a bad jearking, and then a few clicks that sounds like under my dash and then at about 2,500 rpms its ok as long as i keep it up there.. AND then when i get to a stop sign is wants to stall and the idle in park is just fluctuating almost dying after it warms up
Old 03-30-2006, 07:00 PM
maxwedge maxwedge is offline
A990 racer
Re: HELP with Codes
15 is coolant temp sensor voltage reads below -38 degrees for more than 20 seconds so that may be bad, needs a full scan to look at temp reading. 34 is map sensor voltage too low see if you have good vacuum to map
Old 03-30-2006, 08:21 PM
Re: Fans not comming on
Well my problem is half way fixed.. Everything is idling ok, BUT now my fans aren't comming on my coolant temp sensor is new and my relays work, even if i unplug the coolant temp sensor both fans instantly come on. I'm so confused, i think when i turn my car into the ON position i even hear the relays click, and one time the fan even rotated once..
I check the vaccuum to the MAP and its good, i also changed the MAP sensor itself.
I changed the Coolant Temp Sensor, and now my car isn't having the stuttering or idle problems anymore.
Old 03-31-2006, 08:10 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: HELP with Codes
The fans won't come on until temp nears 230 unless you turn the A/C on.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 03-31-2006, 09:00 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: HELP with Codes
Fans are only supposed to run on demand. If they ran all the time before, that was symptomatic of the sensor problem...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 03-31-2006, 09:02 AM
Re: HELP with Codes
Oops...sorry rich, didn't see you there.
...empty gun rack.
Old 03-31-2006, 09:07 AM
richtazz's Avatar
Re: HELP with Codes
no prob Jeff, we both got him covered.
