Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 03-30-2006, 10:38 AM
pk123 pk123 is offline
Tow Haul Problem
2001 Sierra- Automatic.... About a month ago- went to tow a trailer and tow haul wouldn't come on. Kept pressing the button and it finally did. Now tow haul comes on automatically everytime I shift -reverse/drive - it doesn't matter. Was able to turn it off once engaged. Now- even after i've shifted into drive and turned it off, it comes back on automatically and I can only turn it off randomly. I can't seem to figure out what is going on. Any ideas? Thanks.
Old 04-10-2006, 12:14 AM
jaxondes jaxondes is offline
Re: Tow Haul Problem
You probably have a broken or almost broken wire at the base of the shift lever, might be grounding out or something.
Old 04-11-2006, 08:33 AM
pnewcomb1 pnewcomb1 is offline
Mine was a broken wire in the steering column...two screws to drop the bottom cover off...orange wire if memory serves...put on a piece of shrink tube...soldered the wire...shrunk the tube...buttoned it back up...
Look for wire problem right at the base of the shift lever.
...any tool dropped will roll to the exact geographic center of the vehicle.
