Old 03-30-2006, 01:50 AM
hjshort72 hjshort72 is offline
98 Windstar won't start
I have a 98 Windstar 3.8L V6. I came out of my son's hockey practice and it wouldn't start, so I got a jump and it took right off. I drove it home, and it was fine. When I got home, I left it sit for about 3-4 hours went out to run somewhere and it wouldn't start again. It sounded like it wanted to turn over, but just didn't have enough to do it. I tried to jump it, and this time it did not work. I went and got a new battery, and it is still doing the same thing. Could this be the starter? If not, what else could it be? Please Help. Thanks.
Old 03-30-2006, 03:46 PM
phil-l phil-l is offline
Re: 98 Windstar won't start
Does it sound like it's cranking properly with the new battery? In other words, is the "speed" of the sounds it makes while cranking seem like it was before the problem?
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
Old 03-30-2006, 05:39 PM
carlos80 carlos80 is offline
are your terminals clean, both at the battery and the starter?
Old 04-04-2006, 06:08 PM
outwheelin outwheelin is offline
It could be your alternator.
Old 04-06-2006, 10:46 AM
jjjarceo jjjarceo is offline
First you have to check if you are getting spark in you spark plug. Have someone crank the engine and watch the spark plug.
Old 04-06-2006, 11:54 AM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Hello
Did you have your old battery "load" tested to see if it was bad or something drained it.
Was the new battery fully charged? I recomend charging a new battery with a charger so the alt. doesn't have to charge it. The alt will go full bore charging on a battery that is low. This is hard on the alt.
Are your headlights bright? How about other accesseries, do they work? Horn?
How many miles on your 98?
How long have you owen this van? How much history do you know?
When you say "it doesn't do anything" is that nothing, or do you hear clicking when the key is turned to on, to start?
Have you tried to start it in "N"?
When you turn the key on, do the lights on the dash come on, gauges move?
How much voltage is at the battery? At the starter? At the main fuse pannel under the hood? At the pannel under the dash?
Get a digital volt meter. They are cheep (under $20.00 will get you one).
Post back.
Regards
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
