Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 03-29-2006, 11:33 PM
doodad's Avatar
doodad doodad is offline
Send a message via AIM to doodad Send a message via Yahoo to doodad
replacing clutch, help please.
hi guys..
l just picked up a 94 corolla and the clutch is different than other cars..
l have to let the clutch off all the way then the car moves suddenly..ur car's are the same or my clutch is goin bad?
why it is like that?
also if l need to replace the clutch, can l replace by mysefl?
thanks..
Erdal
Old 03-30-2006, 01:21 AM
KimMG KimMG is offline
AF - Advisor
Re: replacing clutch, help please.
Some clutch disks are asbestos free and therefore grab. They can take a little getting use to.
Check out autozone.com
They have free repair guides that maybe helpful in becoming familiar with your car.
Old 04-02-2006, 07:37 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
replaced clutch on my 96 rolla and took me about 8hrs. Also replaced axle seals and rear main seal.
My clutch was slipping and just all arround weak. Replaced it with an Exceedy clutch kit I bought on ebay for 112 shipped. Never had a problem yet, accept my shifter bushings which i am replacing this week so the trans doesnt grind.
Old 04-08-2006, 09:52 PM
doodad's Avatar
so do u think that l can do it myself??
l have never done that..
how much would be clutch kit and what should l do? also which kind of tools do l need?
could u please explain step by step how to do it?
thanks..
Erdal
Old 04-11-2006, 07:38 PM
cheesep cheesep is offline
I wouldn't rush to replace it if its not slipping. It's a hydraulic clutch so you should first check for leaks and make sure the master cylinder is full of fluid. If its not you should top it up and bleed it. How to bleed it can be found at;
http://www.autozone.com/servlet/UiBr...0c.jsp#hd1-1-2
It could be though that maybe after you've driven it for a week or so you'll just get used to it.
If you need to replace the clutch you can do it yourself if;
- you have a good place to work
- you have proper tools including jack stands and a hydraulic jack
- you have lots of time
- you have a Haynes manual or a shop manual. Important for torque specs etc.
- an assistant would also help for pushing, lifting, holding, aligning, tightening etc. and of course giving you advice whether you want it or not.
You have to remove the transaxle first. Look at the following link to see what you are in for and then check out the section on clutch.
http://www.autozone.com/servlet/UiBr...3d8016bc22.jsp
