Go Back   Automotive Forums Car Chat > Toyota > ES300/ES330/Windom
Old 03-29-2006, 09:39 PM
volvotech volvotech is offline
Thumbs down Coolinf Fan inop
I have 94 lexus ES 300 and overheat on slow traffic and i noticed that the engine cooling fan is not working any advise how to fix it thanx
Old 04-04-2006, 08:35 PM
Toysrme's Avatar
Toysrme Toysrme is offline
AF - Advisor
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool Re: Coolinf Fan inop
The connector to the power steering pump relay that turns the haydraulic line pressure from low to high is not connected.
It happens nearly every time a non fluent mechanic changes the drive belts.
There is no failure rate. If the engine is turning over with a belt on it. The power steering pump is working the motor. The only other cause is to burn the fuse out that supplys the cooling fan ECU with power. Which... Never happens either.
It's the wire not plugged into the powersteering pump.
From the top:
From the passanger wheel well:
If you bridge OP1 & E1 in the Diagnostic port in the engine bay with the engine running. It will open that solenoid, causing the fan to spin fast.
If it doesn't spin fast. It's disconnected. If it does spin fast, then the cooling fan ECU's fuse is dead. Replace it.
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
