Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 03-29-2006, 08:25 PM
jimbo1993 jimbo1993 is offline
95 e250 no start condition
help, I have a 95 e250 with a 6 cyl. it won't start, cranks fine, has spark at the plugs, 55 psi fuel pressure with the key on, the fuel pump runs all the time that the key is on, it don't cut off after two seconds. with the original computer I had injector pulse while cranking, with the new computer I have no injector pulse. I don't know what to do next. thanks, jimbo
Old 04-14-2006, 03:27 PM
ModMech's Avatar
ModMech ModMech is offline
Re: 95 e250 no start condition
1) The "new" computer is bad.
2) Do you have any compression?
3) Will it run on Ether? (If so the ignition system and cam gears are ok)
4) It is "never" the computer.
Old 08-31-2006, 12:21 AM
gas guzzler gas guzzler is offline
Send a message via MSN to gas guzzler
check for ground at the battery, a small wire leads to the fuel pump relay under the pass., side of dash, if it is loose ,,, no start
