Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 03-29-2006, 07:15 PM
mcdlnwright mcdlnwright is offline
Unhappy Check engine.. I think I am gonna blow it up
Ok guys here the run down.
I have a great 1990 Bronco, I have had it about 6 months. but ever since I got it I have been having problems with the check engine light. I have taken it to three shops and noone can figure out why. they all say just ignore it. But honestly I just want it fixed I dont want to ignore it.
I can drive it for 10 to 15 minutes and the light will come on. But I could pul over as soon as it comes on and turn the truck off and back on and it would be gone for another 10 minutes. I have checked for vacume leaks. Replaced the TPS, Egr, Brake booster , O2 sensor. Plugs and Wires. but it wont go away. now its reading 4 new codes
42 & 41 & 65 & 67
I ws told that 65 & 67 was nothing except we skipped two steps in the check engine tests.
Help!! I love my truck but I cant keep sinking money into it like this
What do I do!
Old 04-04-2006, 11:34 PM
0tobe60in10minutes's Avatar
0tobe60in10minutes 0tobe60in10minutes is offline
Send a message via AIM to 0tobe60in10minutes
Re: Check engine.. I think I am gonna blow it up
hey. i had a similar problem with my 1995 ford escort wagon. the engine light would come on about 5 minutes after i turned the car on. the code came up to be like 102 or somethin, the cylinder ID sensor which indicates piston ones position. anyway the car wouldnt pass smog with the engine light on so we payed about $1500 to replace a stupid sensor and wires.
what is code 41 & 42?
RIP 88 Bronco II
Old 04-05-2006, 01:59 AM
Truck Truck is offline
How's the oil? I assume you change it every 2999. Do you hear any valve tap? How's the exhaust note? Do you lope at idle?
Of course, I'm steering you towards an oil pump. If you believe the thing is running otherwise fine, I'd leave the gremlins in the computer.
