Old 03-29-2006, 05:51 PM
2K-SS 2K-SS is offline
Angry Demonic Differential Possession
Shortly after picking up my new 2000 SS, I noticed a lot of clunking coming from the differential when coasting with the clutch pedal pushed in. It also made this clatter when coasting under neutral load. I went to the dealer, and after a test drive they pulled the cover to find lots of metal filings. They supposedly "rebuilt" the differential, whatever that means.
After the repair, I picked up the car, and in a short time the rattling returned. This time the dealer said that, according to GM, this was a normal sound for the Torsen differential, and that it was just fine. I spoke with other SS owners, and they heard nothing from their differentials. Anyway, I proceeded to rattle around for a few years, and moved from NM to MO.
Suspecting that the "differattlential" would be a source of problems in the future, I purchased an extended warranty after the factory warranty expired. Good thing.
About six months ago, I noticed a fluid puddle on my garage floor. Took it the local Chevy dealer. They replaced the front seal, which lasted about a week. They then replaced a seal and rear u-joint. They said the gear lash was still within specs, but right on the edge.
OK, long story short...a month after the above repair, a bearing went out and filled the rear end with small chunks of metal. The dealer replaced about $1500 worth of gears, etc. All new..... NOW, the rear end has begun rattling again. PLUS, it has acquired a loud gear whine when applying even a little power on a turn. It only whines on corners when the car has been driven enough to completely warm the diff. fluid, not when it is cold. I called Chevrolet, and the only thing they were interested in was telling me that their warranty expired some time ago, and that technical problems are dealt with through their dealers. Thanks!
My extended warranty company (1Source) just went belly up, so no more warranty. (They did, however, pay out more than I paid them.)
So, a few questions..
1. Any thoughts on why this differential is so prone to problems? There has to be some underlying problem.
2. Should I consider an aftermarket differential?
3. If so, any recommendations?
4. How many $$$ are we talking about?
Other than this, I have no problems with the car. Sure it has body rattles, and is prone to slip around on anything but dry pavement....but that is a Camaro (This is my fourth one...70-1/2, 73, 83 Z28, and this one.)
Old 03-29-2006, 06:31 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Demonic Differential Possession
man i'd just swap the whole rear that way you'll be rid of the evil house of demons.
Old 03-29-2006, 07:48 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
true true^^^^
aside from that a 12 bolt could be found used for about 1800 dollars.
torsen units are supposed to be pretty good. With all of the work that was done to that rear id say that you got a dud.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 03-29-2006, 07:50 PM
or an incompetent tardo poked around in your gears...
Old 03-29-2006, 08:15 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
well since it's really noticable on turns it would point to the spiders which would make me think the axles are bent, hit any curbs fishtailing?
Old 03-30-2006, 12:14 AM
AFI 05 AFI 05 is offline
Send a message via AIM to AFI 05
get an exorcism done to your rear end
1990 IROC-Z 5.7 TPI (1 out of 4,213 IROC's made in 1990) Only mod is magnaflow 3" cat back and K&N filters... im broke.
Old 03-30-2006, 12:17 AM
yeah.. i think you got a dud... replace it. after you spend more money on it.. you might hear the noise again and again..
Old 03-30-2006, 08:39 AM
Thumbs up Re: Demonic Differential Possession
Thanks to all for confirming what I was afraid was the answer.
