Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 03-29-2006, 05:50 PM
Rambler Rambler is offline
95 Explorer Trailer wiring
Ok guys maybe you can help me out,
I have a 95 Explorer and need to wire it up for my trailer, not sure where to connect into it came with a hitch but i dont see a quick connector. Manual tells me nothing so i hope you guys can tell me where to tap into.. to get te lights working correctly..
Thanks in advance,
Rambler
Old 03-29-2006, 08:12 PM
bumpinkicker04 bumpinkicker04 is offline
Re: 95 Explorer Trailer wiring
Thanks in advance,
Rambler
Autozone sells the wiring harness that you will need. If you get a vehicle specific one it will just plug straight in to the harness for your brake lights and running lights without the need to splice any wires. But they usually cost more than the other ones. If you need the wire diagrams then let me know.
Old 03-31-2006, 12:41 PM
If you could please let me know where to locate the wires i need to splice into or plug into.
Thanks,
Rambler
Old 04-03-2006, 06:31 PM
Scatterpack94SE Scatterpack94SE is offline
In the compartment (driver's side rear fender).
Old 06-16-2006, 08:34 AM
yamahar1rida yamahar1rida is offline
Should be a few there on will be under read bumper and if not the other is on the panel on rear driver side back good luck. Mine only worked inside truck panel other didnt do anything. Just a suggestion if you are towing put a 50.00 trans mission cooler kit on it
