1988 bonneville
ok, here goes. hope someone can help.
i bought a 88 bonneville and its not firing on cylinders 2 or 5,i dont have any fire at the coil pack its the 3.8 "c" engine. i have done the following thus far:new plugs and wires new ignition module new coil pack new crank sensor compression test is good on both cylinders im outta ideas guys.... any ideas??? |
Re: 1988 bonneville
Make sure the icm is properly grounded ,check for poor connections at the icm ,wiggle the the wires at the icm check the harness from the cps, switch coils around see if the miss moves if the coils are seperate.
Re: 1988 bonneville
thanks for the reply. grounds and wires look good at both ends
the miss never jumps, also this coil pack is all one piece so i cant swap the coils around thats why i just replaced it
Re: 1988 bonneville
If you have an open wire you will not see any spark jumping, but I assume you are past that. So the icm and coil pack did not change anything? Same 2 and 5?. A weak signal from the cps can cause this or a damaged reluctor on the balancer.
