Go Back   Automotive Forums Car Chat > Toyota > Tercel
Old 03-29-2006, 04:44 PM
98tercel 98tercel is offline
Question coolant disappearing
The mystery of the missing coolant. Where does it go. No leaks seen. Checked out some of same q's by other owners. will try the suggestions given. Thanks to all who gave ideas in regards to other things to check. Hopefully, it's one of those. I'll check in later with a thanks if one of them.
Old 03-31-2006, 06:53 AM
gator2764 gator2764 is offline
Re: coolant disappearing
Maybe a head gasket leaking if you don't see any coolant on the ground??
Old 03-31-2006, 06:44 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
yep, most likely a head gasket.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 04-02-2006, 07:20 AM
KimMG KimMG is offline
AF - Advisor
How much are you losing and in what time period? Do you have white clouds, steam coming out of your tailpipe? Is there coolant in the oil? Is your car running hot? I had the top seam in my radiator fail. The coolant would boil off and leave no puddles. Fill your cooling system, then pressure test the system.
