Go Back   Automotive Forums Car Chat > Honda > N2O | Turbo | Superchargers
N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance.
Old 03-29-2006, 02:53 PM
lancerboy's Avatar
lancerboy lancerboy is offline
Turbo?
I own a 91 civic sedan. I was wondering if the stock d15, first of all, can be turboed and second of all, if it can, what is a safe pressure to boost at?
Old 03-29-2006, 03:13 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Turbo?
1. Anything can be turboed, its just a matter of how much time, effort, and money will it require.
2. Boost pressure doesn't really mean anything, it depends on the size of the turbo you're running. I have a T3T4E 60 .63ar for my GSR and on 11psi it should make a little over 300whp, but that same pressure on something like a T25 would make maybe 220whp.
You have a lot to learn.....read everything about turbos you can find.
www.homemadeturbo.com
www.honda-tech.com
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 03-29-2006, 06:08 PM
lancerboy's Avatar
Re: Turbo?
yeah i meant on stock internals becuase i dont have loads of money, and i know that anything can be turboed
Old 03-29-2006, 11:45 PM
Schister66's Avatar
AF -Advisor
Re: Turbo?
do a compression and leakdown test to see what kind of shape your engine is in......generally turbo d's don't push more than 220whp daily on stock internals......
Old 03-30-2006, 12:46 AM
duffman868 duffman868 is offline
Re: Turbo?
the d15 are extremly weak the rods are the size of a sharpie. d15 usuallly grenade at about 150hp while the d16 can withstand about 200hp. i would just pick up an a6 and boost it
1990 Honda Civic std - ls swap
1994 Eagle Talon dl - daily driver and slow as balls
I should make a paper mache turbo and manifold.. I shall call it.. the SSAutoMache
Old 03-30-2006, 09:55 PM
Schister66's Avatar
AF -Advisor
Re: Turbo?
your best bet is getting the A6 or even a D16z6/Y8 and boosting it......if you have any more questions, just PM me or post them on here
