Oil psi down due to fuel in oil! Why?
Hello
My 97's oil psi was showing below 40 while driving! It's normally above 40. I thought that it just needed the 10w40 summer oil. When I drained it last night it smelled like I just drained the gas tank! I'm also getting around 21-23 mpg. I'm thinking that I may have fuel injectors that leak fuel out when the engine isn't running and it's draining into the oil. Thoughts? Suggestions? I will try fuel injector cleaner. Regards Dan
******************************************* Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK Photos of my repairs: http://dansautopictures.shutterfly.com/ Check this out:http://threewheelmotorcyclemetro.shutterfly.co A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854 95 Windstar 240,000+ 98 Windstar 136,000+ 09-25-2008. 85 Dodge 1 Ton Snow mover gas hog 91 Mazda Protege free beater SW MN |
Re: Oil psi down due to fuel in oil! Why?
Thanks Stuzman...I'll check that out.
Regards Dan
You might want to change out that oil that's diluted with fuel right away. That's wearing your metal parts fast. If you do it yourself,.... if it was me I'd change it today to save wear on the engine parts.
Dan
I checked the fuel psi and it was in range. I left the gauge on for a while with the engine off and the psi held. I also checked the fuel psi reg. and the vacuum held as long as I keeped the gauge on. What else could be causing this much fuel to be getting into my oil? (just to clearify....I have changed out the bad oil) Regards Dan
My 2000 runs below 40 at times, always has, typically when I'm sitting in traffic with no A/C, the engine idles a bit slower. I mean maybe I'm really missing something here but I've done oil changes on a lot of different cars, a number of times. The oil usually has a pretty strong fuel smell in my experience. I don't have the training to know what is a normal amount of fuel odor and what isn't, perhaps if there is a trained mechanic on here he could fill us in. My fuel economy seems fine, I run about 22/23 on surface streets and about 29 or so on the highway. I would rate the fuel odor of my oil on a typical change to be very strong, but I wouldn't say it smells any different from oil changes I've performed on other vehicles.
Pcmos
Thanks for your input! I don't think I've ever smelled this much gas in oil! My wife even complained of the strong smell when I came into the house! I guess I'll keep a closer eye on it. Regards Dan
I've been thinking about cleaning the injectors anyway.
Dan
