Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 03-29-2006, 11:31 AM
Fotiounce Fotiounce is offline
Exclamation 1999 Jetta Electrical Problems
Hello, i recently purchased a 99 Jetta GLS and have been having various random electrical problems.
First, my speedometer randomly stops working or will bounce from 0 mph to however fast I'm driving
Second, my fuel gauge doesn't read how hot my engine is, it stays all the way on cool and rarely goes to the half way point. (which is where it should normally be, once I my car is warmed up, I believe)
Third, when I start the car is almost turns off the second it starts, like it barely has enough power to start or something.
My engine runs good for the most part, will randomly surge and jump when the speedometer isn't working. I know it's some sort of electrical issue, PLEASE HELP!
Old 03-29-2006, 11:35 AM
Re: 1999 Jetta Electrical Problems
^ My 99 Jetta is a 2.0 Automatic
Old 04-02-2006, 07:08 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
1- soundsl like either your speedometer vehicle speed sensor is bad or the plastic ring on the differential is broke.
2- ect (coolant temp sensor) common problem on theese
look in the search for previous posts on theese
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 06-07-2006, 08:09 PM
andi28 andi28 is offline
Hi, I have the same problem, but on a VR6. The additional interesting fact I've noticed is that when the speedometer starts working, the doors lock automatically, as opposed to moments when the speedometer doesn't work and they no longer lock by themselves when I start driving. i would have it's some circuit problem; am I right?
I am a novice, so please be descriptive. Thanks!
Old 06-10-2006, 12:13 AM
GTQVR6 GTQVR6 is offline
This fourth generation jettas have a device that automatically lock the doors at 10mph. That is the reason why they didn't lock when the speedometer doesn't work
