Old 03-29-2006, 11:19 AM
91S10's Avatar
91S10 91S10 is offline
Send a message via AIM to 91S10 Send a message via Yahoo to 91S10
Burning Oil BAD!!!
I have an 89 civic hatch with a 1.6 si. i love the car but its burning way to much oil and i have to put oil in it every week.
Now my question... what could it be? My friends tell me its the head gasket. do u think thats what it could be? thanks for any help!
Old 03-29-2006, 11:45 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Burning Oil BAD!!!
If it's the headgasket you would notice a loss of compression and/or power and may even overheat if your mixing oil and coolant. More than likely your piston rings are bad. Time for a rebuild or a swap or you can just keep adding cheap oil every week. GL
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 03-29-2006, 11:51 AM
duffman868 duffman868 is offline
how mechanically inclined are you or your friends because you can do a ghetto rebuild with the engine in the car and just replace the rings,bearings and gaskets
1990 Honda Civic std - ls swap
1994 Eagle Talon dl - daily driver and slow as balls
I should make a paper mache turbo and manifold.. I shall call it.. the SSAutoMache
Old 03-31-2006, 02:53 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
I'd start by checking the compression. You might "luck out" and it might just be the valve guide seals. That kind of work will "just" require removal of the head. GL
Old 03-31-2006, 03:50 PM
Smoghog Smoghog is offline
Have you replaced your PCV valve? If it gets stuck you will go thru 1/2 a quart in 50 miles.
worth 10 bucks to give it a try.
SH
Old 03-31-2006, 05:25 PM
johnb16a2's Avatar
SH
Also make sure the hose is not clogged. Also, you might want to consider the OEM PCV valve, I've had fitment problems with aftermarket valves in the past.
Old 04-03-2006, 12:14 PM
4thgenSIR 4thgenSIR is offline
I put 2 liters of oil in with every fill in my old si. The rings were done, I'd be willing to bet that your problem is the same. My heagasket went later on so I got a B16 though. Best decision I've made.
Old 04-10-2006, 07:41 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Usually if the rings are bad, you will also get gas in your oil, thats what is wrong with my 93 civic. I should say that is what mine is doing, makes complete sense to me, plus when I swapped heads, I was able to wiggle the piston a little bit too much, so that was a give away on bad rings.
I would try the PCV valve, and then try a compression test, hopefully it is just the valve seals.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 04-11-2006, 05:37 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
could also be valve seals as well. Does it smoke in high rpms, or does it smoke upon start up? or both?
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
