Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-29-2006, 09:04 AM
Paul A Paul A is offline
Guages gone nuts - Please Help!
Hi,
On my 2.2 (Petrol) Rodeo the guages sometimes fail to work (Rev counter,temp,Speedo,fuel).
The only way to get them working seems to be to push (hard) on the odometer trip reset button!
I've tried out the instrument cluster on my other Rodeo (2.2. Diesel) and it works fine - All the time!
Is it possible for a bad earth to the instrument cluster to cause this?
Anyone else had this problem??
Thanks in advance .....
Oh ... its a 1999 model with electronic speedo.
Old 03-29-2006, 07:49 PM
96IsuzuRodeo 96IsuzuRodeo is offline
Re: Guages gone nuts - Please Help!
It sounds like it is a loose or corroded ground connection. If you have a Haynes manual, you may be able to find out where all of those gauges are grounded and check that connection.
Old 03-29-2006, 09:53 PM
directory's Avatar
directory directory is offline
i'd have to agree...
check for a loose connection in the wire harnesses.
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
