Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 03-29-2006, 07:10 AM
amari amari is offline
2005 Envoy V8- How to get ecu codes????
I have 2005 Envoy V8. A check engine light came on today. Is there a way to read or get ecu codes without an OBD reader. Also, how to reset the light.
Any info will be appreciated..
Regards
Old 03-29-2006, 09:55 AM
maxwedge maxwedge is offline
A990 racer
Re: 2005 Envoy V8- How to get ecu codes????
You need an obd11 scanner and then diagnose the problem, not just reset the cel. Should be under warranty for this.
Old 03-29-2006, 10:59 AM
Thanks maxwedge for the reply. The car still under warrenty, i just wanted to find out the codes before taking the car to the dealer. I thought there would be an On Off On Off for the key to get the codes out before reseting.It would be just for future reference.
Regards
Old 04-04-2006, 03:39 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
Dodge is the only one that will display the trouble codes by cycling the key 3 times. If you want to check the codes your self you can pick up a code reader from an auto parts store, the basic one runs between 80 and 90 dollars.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
