Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 03-29-2006, 03:09 AM
hany's Avatar
hany hany is offline
Exclamation cancel key code
my friend need to install new engine in his 96 . and he worry about the key code . becasue he will install new engine with new ECU . and worry the engine not start .? so how can i cancel the key code ?
MY ENGLISH IS NOT PERFECT. sorry for that
1992 CIVIC 4DOOR ULTRA BLUE TURBO -SOLD
1996 CIVIC 4DOOR EUROPIAN VTEC LS
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 03-29-2006, 02:17 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: cancel key code
As far as I know the only thing that needs a code is the OEM stereo. The computer should work fine. GL
Old 03-31-2006, 03:24 AM
hany's Avatar
Re: cancel key code
what i mean adjust is : my friend installed b16a4 engine model 96 but his car is 92 dx. compelet swap harnes and ecu and auto tranny . but it did not start. the macanic man say it not start because the ecu has lock code that will not make the car start unless use the orignal key which came with the engine. so how can i cancel that lock code ?
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 03-31-2006, 02:03 PM
johnb16a2's Avatar
Re: cancel key code
I think your mechanic friend is confused. Such a system is (was) used in GM cars and other cars but I am not aware of a similar system used on Civics. If the engine turns over easily I suspect ignition or fuel problem. GL
Old 03-31-2006, 04:59 PM
hany's Avatar
Re: cancel key code
what you mean is the ecu has no problrm to be install in other car ?
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 03-31-2006, 05:47 PM
hxgaser hxgaser is offline
Re: cancel key code
Hany, I always thought that the 7th gen civics were the first generation to use immobilizers. Before that, civics did not use immobilizers. There should not be any issues with ECU locking up due to wrong key use.
Old 04-02-2006, 12:56 PM
hany's Avatar
Re: cancel key code
hmmm it may be the harrbess because he use a RHD harness in LHD CAR and make in it some changes. any way thanks alot for your attention.
2003 CIVIC LXI
1999 GOLF 4 1400 CC
