Old 03-28-2006, 08:57 PM
Corey96LS Corey96LS is offline
96 Blazer Mirror Problem..
ok, well the other day, i went to adjust my mirror on the blazer, and it seems as if the left and right function will not work on the driver side mirror.. it works on the passenger side, and the up and down works on the driver side.. i cant begin to imagine what is wront with this.. if you have any suggestions, please let me know.!
thanks.!
Old 03-29-2006, 03:58 AM
muddog321 muddog321 is offline
AF -Advisor
Re: 96 Blazer Mirror Problem..
The switch contacts get dirty or corroded so hit that button a few times more and bet it will work. Anyone had luck with contact cleaner on these?
Old 03-30-2006, 07:51 PM
ive tried hitting it a few times, does nothing.. could the contacts be dirty, even if the passenger side still works.?
Old 03-30-2006, 09:09 PM
Eslhockey92g's Avatar
Eslhockey92g Eslhockey92g is offline
this may help,
but a while back I couldn't put down the windows unless, it was put down by the driver's master panel. After playing with some of the wireing, I traced it to the window lock switch. So i was just gonna buy a new one, and i figured since im gonna trash it any way, i mine aswell see how it works, So i poped the rocker off, and the contacs were all ceroded. SO i took off the metal pice, cleaned and put it back together and it works like new. It just needed a lil cleaning
If the contacs in the mirror are the same as the window they may be dirty, I know ive had the windows down a few times and when the wipers wipe, the water run off comes right in the car, and seaps down the switches
May be its somthing simple as that
Old 03-31-2006, 11:23 AM
thanks muddog, i tried what you said, and now it works like a dream.!
Old 03-31-2006, 03:30 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Happend to me as well.
Grab the mirror casing and with one of your two thumbs push the mirror on its gear.
You will here is jump a couple teeth and will reseat the mechanism on the track.
Works everytime for me.
1995 Factory Blazer Service Manual for sale, PM if interested.
