Old 03-28-2006, 08:37 PM
sudin36 sudin36 is offline
Remote stopped working on '93 Ultra
The remote stopped working. The battery is okay -- whatever, the remote doesn't work anymore. Could somebody inform me where I can get a new remote that works on this car? Or how I can repair my current remote. Thanks.
Old 03-29-2006, 05:31 PM
jag_man653 jag_man653 is offline
Re: Remote stopped working on '93 Ultra
If you are talking about the key fob remote entry clicker you can replace the battery. there is a tiny philips head screw on back. Remove it, carefully open case to reveal the battery. go to Radio Shack and get new one.
Ed
Old 03-29-2006, 10:23 PM
I've replaced the battery. And, it still doesn't work. I was wondering about getting a aftermarket remote. Do they work very well? Thanks.
Old 03-30-2006, 12:10 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Do you have 2 remotes or just the one you use? If you have 2, does the other one work? If not, then the problem lies in the entry system itself.
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 03-30-2006, 10:04 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
You may need to reprogram the remote (see below), if that don't work, try EBay for another one. If you get another one, it will have to be programmed to your car anyway!
Jump the (ALDL) Assembly Line Diagnostic Link. You will find this connector under the driver side dash, but you will have to look through a square cut out in the panel to see the connector, it is recessed behind that panel, almost directly under the steering column.
Jumper pin A to pin G with a fused jumper (3A)
Doors will lock and unlock
Press the UNLOCK button on the remote
Doors should lock and unlock again
if you have more remotes press their unlock button (up to 4)
remove jumper wire
________|________
[F] [E] [D] [C] [b] [A]
[G] [H] [J] [K] [L] [M]
Old 03-30-2006, 10:23 PM
Currently, I have only one remote. How can I purchase one or two new remotes and have them programmed for the car. Thanks.
Old 03-31-2006, 09:46 AM
HotZ28's Avatar
AF Moderator Elite
Follow the procedure above and you can program up to four (4) remotes.
