Old 03-28-2006, 06:27 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Dremel VS die grinder
Ok, so I know for porting you are supposed to us a die grinder over a dremel, but why? What sets the dremel apart from an electric die grinder?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 03-28-2006, 07:02 PM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
Re: Dremel VS die grinder
When 99.9% of the world refers to a die grinder they are reffering to one that is powered by compressed air. They are better because they have 25X more nut to them than a dremel ever thought of having.
Got AWD?
Some people buy super cars, other build them
----Click It, For Mods and Pics----
'95 Mitsubishi Eclipse GSX - For Sale
'05 Volkwagen Golf GLS TDI - My daily driver
'03 Ford Excursion 6.0L PSD 4x4
'13 Ford F150 FX4 SCREW 4x4 3.5L EcoBoost
'08 Buell 1125R
'83 GMC Sierra Classic K2500 4x4 - Future Cummins Swap
Old 03-28-2006, 07:11 PM
MexRocket's Avatar
MexRocket MexRocket is offline
word....
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 03-28-2006, 07:24 PM
Thor06's Avatar
Jizzed In My Pants
So does balls = power?
Old 03-28-2006, 08:40 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
i have a die grinder at work for patching tires lol. u gota sand off all the ridges n shit inside the tire before you patch it. im just gana use it when i do mine.
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 03-28-2006, 09:06 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
die grinder just works so much better, faster smoother and it doesnt get hot
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 03-28-2006, 09:20 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
An electric grinder vibrates really bad, so bad you can't use it too long.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 03-29-2006, 01:25 AM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Die grinder is used for taking out chunks of metal, but u can use a dremel after to smooth everything nice
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 03-29-2006, 10:00 AM
SLoe's Avatar
SLoe SLoe is offline
^If you have to finish with a dremel, you are using the wrong bit in your die grinder. Throw that fucking dremel in the garbage You have to use the appropriate bit for the job, and material. I can make a smoother cut with my die than with a dremel, because I can control the speed of the cut better.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 03-29-2006, 12:25 PM
Mine is one of those cool adjustable ones with like 10 speeds with a 35k rpm max the dremel that is
95 Eclipse GS-T
Currently:
Soon lol
Old 03-29-2006, 03:35 PM
SLoe's Avatar
The other reason I don't like them is because you can't get a very large bit , and they have no nutz!! A long time ago I tried to gasket match a head with a dremel NOT FUN!!!!
Old 03-29-2006, 07:49 PM
Thor06's Avatar
Jizzed In My Pants
Thanks guys. I will keep the dremel though, I still like to carve wood . Also, I thought the sanding/buffing wheels might be nice to polish the letters on mine and Mikes valve covers when we paint them. I was hoping an electric one would suffice so I could do it at home and not have to drive to the shop, but its not that big of a deal. Its an off brand, but the tool itself and 200+ bits and shit was $20. Thanks for the input guys!
Old 03-29-2006, 10:52 PM
kjewer1 kjewer1 is offline
AF - Advisor
Dremels are like Hondas. 35k rpm and .1 ft-lb of torque.
I have electric and pnuematic die grinders. The electric has more torque, but the air is so much lighter and easier to control speed, I always go back to the air powered grinder.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-29-2006, 11:01 PM
blk_srt's Avatar
Well put
Mods:
Old 03-30-2006, 03:16 PM
SLoe's Avatar
Well put! If you ever use an air/elec. you would throw rocks at your dremel. Plus, beyond the initial expense of the air compressor (worth every penny, you can pick up a decent die grinder for $10-25 at harbor freight. The selection of air tools is limitless.
