Old 03-28-2006, 04:56 PM
Igovert500's Avatar
blue + red light magnet
$114 for 99 lifters
I remember when I was shocked to see them at $168...now they can be had for $114 (possibly for a limited time only). If I had a job, I'd be all over these. Just thought you guys would all want to see this.
http://www.3si.org/forum/showthread.php?t=316191
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 03-28-2006, 10:06 PM
AutostradaVR4 AutostradaVR4 is offline
Re: $114 for 99 lifters
SWEET! Thanks for the heads-up, Igo. Just bought a set!
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 03-29-2006, 10:03 AM
mehrshadvr4 mehrshadvr4 is offline
what 99 lifters realy do?
Old 03-29-2006, 10:42 AM
better oil flow...get rid of the lifter tick...
Formerly BlinkRA182
Old 03-30-2006, 12:29 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
thanks a lot for the info! i might just get a set in a week or so. i had lifter tick once, then it went away after a few oil changes. this group buy is almost too good to be true. its one of those things that you might as well go ahead and purchase, just in case you get lifter tick, and it can only improve oil flow.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
