Pressure test Cooling System
Someone mentioned testing the cooling system and I started thinking about it a bit but I felt it deserved its own thread.
I am wondering how I can rig up something to pressure test my cooling system. My first thought would be to somehow attach my regulated compressor output to the rad cap (missing on my Windstar however). This of course would be destructive to the rad cap so I would have to buy one for my "tool" which of course would not test my cap. I would then apply the presuure to the system and look for leaks. Am I thinking about this the right way? Does anyone have any ideas? How do the pros pressure test a cooling system? Since the Windstar does not have a radiator cap is there a better way or place to introduce pressure? |
Re: Pressure test Cooling System
Your model Windstar doesn't have a radiator cap or a reservoir ... it has a "pressure relief cap" and a "degas bottle". Hoorah for jargon!
The shop manual shows unhooking the smallest hose that goes to the top of the degas bottle and installing a test (tee) adaptor. To this adaptor, you attach what looks like a bicycle tire pump with gauge. You pump up the pressure until the pressure cap relieves. You're suppose to get at least 13 psi but no more than 18 psi. After this, you watch the gauge for a long period, hoping it will hold at the relief pressure ... indicating no leaks. BTW, my year-long coolant leaks are no secret ... they are at the front cover, and I'm finally about to jump in and replace the cover gasket in the next few days. |
Can you take pictures and post them when you do the timing cover?
Take them...and we will figure out a way to get them posted for other's to view. LouisNC has a site that you should be able to post them directly to....... Alldata lists the FORD standard repair time for the timing cover gasket at 13.5 hours. So be prepared for a lot of work. I plan to replace my lower intake manifold gaskets.....just bought them today..... I plan to take pictures of that and post them......hopefully it works out..... |
Sence cooling system is the topic....I've got a thought...
You know on a boat it has an alarm for no oil psi or over heat.... What do you guys think about a psi sensor on the cooling system? Is the system looses psi, you can shut it down before an overheat. Thoughts? Regards Dan
******************************************* Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK Photos of my repairs: http://dansautopictures.shutterfly.com/ Check this out:http://threewheelmotorcyclemetro.shutterfly.co A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854 95 Windstar 240,000+ 98 Windstar 136,000+ 09-25-2008. 85 Dodge 1 Ton Snow mover gas hog 91 Mazda Protege free beater SW MN |
Wiswind,
Yes, I will take pictures and they will be available for whomever to post (I still don't have this skill). BTW, I intend to try a "new way" of getting access to the front cover ... it involves "swinging" the subframe. The reason is ... I also need some extra access to the tranny for some internal seal replacements (I think the Mercon has finally gotten to me!). LeSabre, I think sensing excessive high temperature is the way to go, because the coolant will continue to boil-off until the last drop. This will keep the pressure "up" until the engine is scorched ... but the pressure won't appear as "high pressure" because the relief cap is steadily dumping at 18psi. |
