Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 03-28-2006, 02:42 PM
katman96 katman96 is offline
Unhappy Fuel filter connector damaged
I can remove the rear line/connector from the fuel filter on my 1991 explorer, but the front connector will not come apart. I have the proper tool, it worked find for one connector but not the other. Talking to a few people, they said the "quick connect" is damaged internally.
I was thinking about replacing the fuel line, it is only about 24" long but, the fuel line is not available unless I buy a set of them for $200.00. I was told that I could reach into the connector and pull out the little spring clips that are in there (those are available as a replacement part from Ford) and then replace them once I get the filter out. I just want to see if anyone has done that and if they had any suggestions.
Thanks in advance
Old 03-28-2006, 05:58 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Fuel filter connector damaged
We have replaced a lot of the locking clips on Fords. All you gotta do is get filter out of line. The clips are readily available at dealers.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 03-28-2006, 06:53 PM
way2old, so all I have to do is pull the clip out of the tube using a dental pick and some needle nose pliers? I cannot open the reatiner on the one side so the filter will still be in the connector. Will I stilll be able to pull the clips out of the fitting with the filter attached?
Sorry I just want to understand this before I tear this thing apart and immobolize my only vehicle.........
Thanks
Old 03-29-2006, 06:42 AM
way2old's Avatar
TOKEN HILLBILLY
The filter will have to be removed to get the clips out. We use a small hacksaw and cut old filter as close to line as possible then fish the clip out. It is time consuming.
Old 03-29-2006, 07:50 AM
I see, well Ill give it a try and let you know, thanks.....
