Old 03-28-2006, 02:05 PM
wheelman216 wheelman216 is offline
squeaking on turns
when the car is at a complete stop and i start making a turn, it makes a loud squeaking sound, its also kinda bumpy, but when the car is running, the car turns fine withouth the squeaks, any idea what this is or the cost for fixing this, or is this something easy to fix?
thanks
Old 03-28-2006, 02:27 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Re: squeaking on turns
I've never heard of that before. Could it be the power steering has gone bad? When you say it doesnt do it when its running are you making sharp turns and when it is running your mabye just going around a curve and the wheels aren't turned as much?
Old 03-28-2006, 02:30 PM
2old 2old is offline
The belt running the steering pump is loose or worn.
The reason why it just happens with you are at a dead stop is because it's harder for the steering pump to a turn a wheel that is not moving because it has to overcome the friction of the tire to the ground (not many people remember the days before power steering).
Just change that belt out and you should be okay. (and try to avoid turning the steering when not moving, you can wear out other parts more quickly that way).
Old 03-28-2006, 02:35 PM
Igovert500's Avatar
blue + red light magnet
^ Sound advice as always.
Also first things first, I'd check the PS fluid. It's probably the belt, but it doesn't hurt to check and see if you are low.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 03-28-2006, 02:48 PM
its not the power steering fluid, its full, i noticed it because i was making a u-turn, so i backed up, turn the tires, and i noticed the squeaking and bumping. i dont really turn the tires when parked, it just happened. thanks for the advice.
Old 03-28-2006, 04:03 PM
Igovert500's Avatar
Well I'd start with the belt as 2old said. If it isn't that, then start inspecting your wheel bearings, cv joints, etc.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 03-29-2006, 09:11 PM
i checked and it is the belt. the thing is im not very good with these things, i already bought the belt, i just need to know whats the cost of fixing this and is it safe to be driving it, since its all i have?
Old 03-30-2006, 10:34 AM
It shouldn't take a mechanic more then half an hour to install so even at the dealership you are looking at most $50...
It's not dangerous to the vehicle to drive it like that aside from the noise... I wouldn't ignore it forever because the squeal will only get worse and if it breaks you lose power steering (I can't remember what else is running off that belt).
