| Diecast Car Modeling Discuss and show diecast vehicles that you have modified, or that you have collected. |
LED Tut...
Well I took like 5 minutes and drew up a small tut on LED's.. I had to use 8 on the underglow for the magnum.. You have to run them in a series of 4.. running them in a series of 4 distributes the power evenly between the LED's so they arnt over powered causing them to burn out and smell really bad when they do. if any more than 4 are added to the series they will be under powered and not be bright.. This is how I ran it up.. ( but I have to wires comming off the switch for 2 series of 4 for the underglow)
Hope this helps Ok I did not realize that the picture was so small.. the rectangel thing is a 9v batterie.. the wire comming off with the little box is the on off switch comming from the possitive leg of the batterie, then that is ran to the positive of the first LED, and the negitive of that LED is ran to the positive of the next LED ( do that for 4 LED's) and then run the last LED negitive to the negitive lead on the batterie.. sorry guys
Re: LED Tut...
thank you! this is pretty sumple.
![]() ![]() ![]() ![]() ![]() ![]() ![]() those stupid refs! feb dotm runner up! march dotm winner! |
Re: LED Tut...
so you dont need a transistor or resistor or whatever it is?
Ride #1: 1994 Mercedes-Benz W124 E320 Coupe (My first car/love) Ride #2: 1975 Mercedes-Benz W116 280S (The restoration/hobby/project car) ~Chris~ My Diecast Collection! |
Re: LED Tut...
nope.. not if you wire them in a circut of 4. it lowers the 9vs down to distribute it evenly through the 4.. if you use less.. it will be over powered and probably burn them out after a short period of time.. or if there is more than 4 they will be under powered causing them to be really dull. You can run multiple circuts of 4 off one 9v batterie.. I have 2 circuts of 4 for the underglow on the magnum
Re: LED Tut...
thank you.. it'll greatly help some people
very simple
proud owner of a 2003 Ford Mustang GT![]() my h3 hummer rulez!! VISIT MY CAR ROOM http://www.automotiveforums.com/vbul...d.php?t=521391 |
