Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 03-28-2006, 01:33 PM
shifty1 69 shifty1 69 is offline
Traction Control not working & ABS light on
Hello all, I am new to the board and I am glad I found it.
Here is a small intro, my name is Rob and I am the new owner of an '02 Impala LS (loaded to the nuts including Sports Appearance Pkg ), it has 90km (I am in Canada, so approx 55mi for you 'mericans ).
Well, I just picked it up from the dealer yesterday and everything went well on the hour drive home. Later that night I go to pull it in the driveway and I see the "Traction Control Service" alert come on, and the "Trac off" and ABS lights stay on. I assume that since there is a problem detected in the TC system that it shuts it down automatically (and not allowing me to turn it on)?
My question is this:
Is there a possibility that the codes for the TC were tripped when the car was put the the Emissions Test (E-test)? As the garages have to put the front tires onto the rollers, would the system confuse that for "spin" and trigger an alert in the system?? I am not sure if this is a possible explanation, but it just seems to me that it may be.
Also, would/could the ABS light be directly linked to this??
A little background - Last night the lights/messages came on etc. This morning, they didnt come on at all on my way to work (45 min drive or so). But at lunch they came on again. In the ride in this morning (while the TC was working) I was able to shut it off and on, but when the service code is tripped I am unable to turn the system on.
Everytime the TC has failed the ABS light has stayed on, but when the TC was working the ABS light was off (leading me to believe that the problem is related).
If its not likely to be the e-test as the culprit, please provide any ideas as to what you might think the problem is?
Wheel bearing??
Thanks in advance,
Rob
Old 03-28-2006, 03:13 PM
maxwedge maxwedge is offline
A990 racer
Re: Traction Control not working & ABS light on
Needs to be scanned for abs codes to diagnose this problem. Welcome to AF, if you do not get expected responses here, since the drive train is the same as a Lumina you could post there, seems somewaht more active. Plenty of qualified people on AF.
Old 03-28-2006, 04:49 PM
phewop118 phewop118 is offline
I think there is a thing with w-bodies where a wire can become loose at a wheel speed sensor. This would throw both a traction control and abs code, as neither are able to work w/o the sensor. Search the forum for more, because I know i've seen it elsewhere. Check all wbody ones (grand prix, lumina, regal, century, intrigue...)
Old 03-28-2006, 05:09 PM
bigrod118's Avatar
bigrod118 bigrod118 is offline
have had multiple posts about this, everytime it was the wheel speed sensor. It CANNOT be replaced by itself, it is built into the hub itself. only problem is, you have 4 hubs and no idea of which one is created your problem. I believe the only way to find out which hub it is, is to connect a techII to the car. Which unless you have a shop around you with one, the dealership is the place to go.
Old 03-29-2006, 01:24 PM
Thanks for the responses.
Quick update - It hasnt come on since lunchtime yesterday and I have been doing everything I can to piss it off, lol.
Taking off trying to get it to spin/engage TC (which it did and worked fine), turning it on/off etc but no sign of it.
Doesnt even flash the code in the message center when I shut the car off (which it was showing when I shut it down as of yesterday).
I wanted to clear the codes and start fresh to see if it was something that was tripped when it was put thru the e-test, but didnt want to pull the battery cable (I do believe that would screw up my factory CD if I was to do so).
Does the CPU purge the codes on these periodically?? If not then I would think the code would still be active and alerting me??
If not, how would I go about purging the existing codes??
Thanks again in advance.
Rob
Old 03-29-2006, 03:23 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Most likely you have a bad wheel speed sensor or harness connection to the wheel speed sensor. You will need an ABS capable scanner to determine which wheel. It is possible that on a 2 wheel dyno, the front wheels spinning and the rear wheels stationary caused the light to trip, but unlikely. Since it has continued to come on/off intermittently, I'd suspect a wheel speed sensor/harness is bad, especially if you live in a pothole infested area. Moisture intrusion is the other killer of ABS sensor equipped hub bearings.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 03-29-2006, 05:12 PM
bigrod118's Avatar
disconnecting your battery will NOT screw up your radio, most you'll have to do is reset your radio settings and all the features.
As far as clearing the codes, if the SES light isnt on, there arent any, but you can jsut go to autozone or checker and have them clear the DTC when your SES light is on.
Old 03-29-2006, 06:43 PM
billyo69 billyo69 is offline
traction soon, ABS light....hmm I'm not alone
NAIOA Impala Forums Forum Index -> Problems with my car!
View previous topic :: View next topic
Author Message
Trouttrooper
Newbie
Posts per day: 0.29
Medals: 0
Posted: Fri Mar 24, 2006 12:37 am Post subject: Service traction soon, ABS light....hmm I'm not alone
My wife called me this morning in a somewhat panic saying that halfway to town the service traction soon light came on, traction turned off, and ABS light came on. They went back out, then later came back on for a few seconds. Only did it twice.
I've looked at the other threads concerning this and have a couple questions of my own.
1. Has anyone ever solved the problem without having to replace the sensor/hub? or am I looking at having to replace a hub or two.
2. Can an OBD scanner tell me which hub set the light or is that a Tech2 thing only.
I'm going to jack the car up this weekend, pull all the tires, make sure all plugs/wires are connected, and hose off any road grime. Crossing my fingers that's all it takes.
If it wasn't for all the lights and chimes that go off when it happened I'd probably not worry about it too much. However I don't want my wife to have to put up with it for too long (she drives it 110 miles/day).
_________________
2000 Impala 3.8 base (with darn near all the LS features)
2005 Silverado LS K3500 SRW 8.1/Allison (my beast)
1995 Lumina LS 3.1 (180,000 miles and still going)
Back to top
billyo
Cadet
Posts per day: 0.91
Medals: 0
Posted: Fri Mar 24, 2006 7:01 am Post subject:
My 01 Ls has been doing it for a while now.It has been getting progresivly worse. It is to the p[oint now where the warning lites stay on. I am going to try to see if i can find out which hub it is without bringing it to the dealer.
Back to top
redimpulse
NAIOA Moderator
Bronze Contributor
Posts per day: 7.09
Medals: 1 (View more...)
Posted: Fri Mar 24, 2006 10:29 am Post subject:
1: No; pretty much you're going to have to repllace a hub or two.
2: I think the only way to find out definitively is with a Tech2, but I could be wrong.
_________________
There's an L67 in my garage. But you don't want it.
People who live with their parents are psycho killers. Every serial killer or mass murderer has lived with his parents or a guardian at one time or another...
Back to top
1ImpalaLS02
Senior Level
Posts per day: 2.9
Medals: 0
Posted: Sat Mar 25, 2006 12:33 am Post subject:
Ok, now this also just started to happen to my car recently. I happend today while I was sitting in the car for about a half hour eating lunch. It also happend one time last week.
The Chime goes off and I see the service traction soon light, that goes off and I see the ABS light is on.
I turn off the car off and turn it back on... then a few seconds later I see the security light is on.
Can anybody point me in the direction to be looking for a problem so i can fix it before I get stuck somewhere.
_________________
2002 Impala LS Wht. 1SC
WizAired CAI, 180 tstat, GMPP Exhaust, JimmyC v2 3" DP, ZZP O2 Sim, ZZP Fan switch, ZZP Alt rewire,
ZZP Gen2's, PRJ wires, AP605's, Denso O2, Brembo Rotors/Hawk HPS, 3M Tint, Mobil 1
'04 GP GT2 stock
Back to top
Trouttrooper
Newbie
Posts per day: 0.29
Medals: 0
Posted: Sat Mar 25, 2006 12:52 am Post subject:
I don't believe you will be stuck anywhere. It's just a wheel sensor not working right. At worst you don't have traction control and possibly ABS (?) The car will still drive.......i think
_________________
Back to top
billyo
Cadet
Posts per day: 0.91
Medals: 0
Posted: Sat Mar 25, 2006 9:15 am Post subject:
You wont get stuck somewhere.It will get progressivly worse happening 2 or 3 times a day and then finally everytime you start the car
Back to top
1ImpalaLS02
Senior Level
Posts per day: 2.9
Medals: 0
Posted: Sat Mar 25, 2006 12:49 pm Post subject:
I hope you all are right, i hate getting stuck out in the middle of no where and all. I do hope its just a wheel sensor but I am pulling up 2 wierd codes on my scanner that make me think something else may be wrong.
They are P1626 Theft deterrent..... lost class 2 communications with the BCM and U1064 PZM Serial Data Fault.. loss of BCM/DIM/SBM communications.
I will write down exactly what the codes say.... but from what i can remember that is what the codes read as.
I hope I'm not looking at a BCM problem on top of my transmission problem.
_________________
'04 GP GT2 stock
Back to top
jbackos
Cadet
Posts per day: 0.13
Medals: 0
Posted: Sun Mar 26, 2006 4:54 pm Post subject:
Disable TC by pulling the fuse.
TC progessively turns off injectors while braking. Turning off injectors while at high RPM is not good. This is a GM screwup.
Several owners of Supercharged vehicles have popped pistons due to uncontrolled and overly hot combustion when the injector is shut down. It would have been much safer if GM had chosen to cut the airflow to the MAF and air starve it.
_________________
2004 SS Indy - IPCM, HP Tuner, AFC 2.2, Wiz CAI, ZZP MPS 3.3", Oversized tensioner, 1.9 rockers, oil restricted pushrods, LS6 springs, SLP Headers with cat, U-bend delete, GMPP exhaust, EGR deleted, MSP tranny pan, Alternator rewired, TB Screen removed, caspers fuel pump hotwire, AL 104, Accel wires
Old 03-29-2006, 06:46 PM
bigrod118's Avatar
hey billy, its alot easier to read, and just easier for you, if you just use a link.
http://www.naioa.com/v2/modules.php?...ewtopic&t=7771
Old 03-29-2006, 08:30 PM
ok thanks .I will remember that
Old 06-05-2007, 09:52 PM
rhagfors rhagfors is offline
1. Turn the ignition to ACC or ON. The radio must
be off.
2. Press and hold the TUNE or DISP knob on the
radio for at least five seconds until SETTINGS is
displayed.
3. Press the SEEK or PSCAN up or down arrows
until TIRE MON appears on the display.
4. Press the PREV or NEXT button to enter the
submenu. RESET will be displayed.
5. Press the TUNE/DISP knob to reset. A chime will
be heard to verify the new setting and DONE will
be displayed for one second.
The low tire pressure monitor is now reset.
This reset the lights and computer. Until it stays on continuously, there isn't a mechanic that can fix it! Drive ON!
