Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 03-28-2006, 10:55 AM
bouncdchk bouncdchk is offline
Only getting heat no matter what the temp setting is
I'm having a problem with my truck only giving heat no matter what the temp setting is.
Even when I turn on the air conditioning it spits out heat.
I'm not very mechanically inclinded but would like to fix this myself if possible.
Pete
Old 03-29-2006, 10:21 AM
2000mudder's Avatar
2000mudder 2000mudder is offline
Re: Only getting heat no matter what the temp setting is
need more info on trk!!! look at valve inline with heater hoses from engine to firewall first. have someone move the hot/cold selector switch back and forth to see if valve is opening and closing. start there!!! there is also a common prob with the blend door behind glove compartment so do the same at that valve with the other heater control(diverter switch)
