Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-28-2006, 10:52 AM
drdrew33 drdrew33 is offline
Problem with Idle 99 Rodeo
Inadvertently the engine will race, sitting at a full stop, or in park up to 3k RPM. I already cleaned out the egr valve and the CEL isn't on. Any ideas what might be causing this? 65000 miles.
Old 03-28-2006, 11:42 AM
mapua82 mapua82 is offline
Re: Problem with Idle 99 Rodeo
Might be the intake manifold gasket. Some tech can determine a hissing sound in the engine suggesting a vacuum. Erratic idle, engine stall on stop, etc were symptoms of IMG failure.
'99 Rodeo SLE 3.2L V6
'01 Camry CE 2.2L
Old 03-28-2006, 01:02 PM
amigo-2k amigo-2k is offline
Isuzu Guy
http://isuzufaq.ibctech.ca/#faq5
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 03-28-2006, 01:12 PM
Thanks, I'll check out the gasket this weekend.
Old 03-31-2006, 07:23 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
dont know if you figured it out yet if not dont mess with intake gaskets find the wire that goes to the power steering pressure switch its on a bracket right behond the P/S pump once you have found it disconnect the connector.
the reason it runs up to abot 2500 rpm is because of debris in the switch it does not need to be connected will not cause a cell light to come on its only there to boost idle when turning, like this engine is in need of this..
