Go Back   Automotive Forums Car Chat > Mazda > Millenia/Xedos 9
Old 03-28-2006, 10:29 AM
David2Brown David2Brown is offline
Mazda Millenia 95-02 Keyless Entry Remote Programming
1. Remove key from steering lock.
2. Close all doors.
3. Open driver side door and leave open.
4. Perform the following steps within 24 seconds.
a. Insert key in ignition.
b. Turn key to ON and back to OFF, 3 times ending in OFF.
c. Remove key
d. Push driver door frame button three times (black rubber button located right
on the door beam on the lower part of the door threashold that tells the vehicle
whether or not door is closed. Your interior lights should go on and off each
time just as if you were opening and closing the door.)
5. Buzz sound or chime should be heard at this point signaling that the vehicle is
now in programming mode. If not, wait 40 seconds and return to step 4.
6. All transmitters need to be programmed at this time, including the old ones. Push
any button on the transmitter two times. A buzz sound or chime should be heard at
this point signaling that the vehicle has accepted the new transmitter code. If there is
only one transmitter, repeat this step two more times using the only transmitter.
If there are two transmitters, repeat this step two more times using the second transmitter.
When done programming wait about 5 to 15 seconds and you’ll hear the buzzer sound off 4 times.
This means you’re all programmed.
