Old 03-28-2006, 01:59 AM
klutz_100's Avatar
Translation help [Japanese]
Could someone please help by providing English translations for items marked 1 through 6?
BTW why don't Acustion and Hassegawa provide international packaging!?
Many thanks
Old 03-28-2006, 02:46 AM
DocDann DocDann is offline
Re: Translation help [Japanese]
Don't bother with trying to use online translation, or you will probably get those typically great results such as "Do only one of the following under the below. If you this do, it might work not as well as you think it might not work. This is the way only do it, and do it any other way will work not."
(that is a result I got a few years back on an external drive bay when translated from the website itself)
Old 03-28-2006, 07:56 AM
MattRS2000 MattRS2000 is offline
I can do a little Japanese, I cant do the Kanji, but they dont use that for car words anyway usually.....
1 Parts
2 Catch pin (maybe, the picture is not very clear)
3 Etching parts spec
XXXXXXXXXXXXXX stainless
4 Driveshaft is 2 XXXXXXXX boots
5 Driveshaft boots X 4
6 Winker (indicator / turn signal) X 2
Hope that is of some use to you
Matt
Old 03-28-2006, 08:10 AM
klutz_100's Avatar
Thanks Matt!! Welcome to AF- I'm proud to be one of your first posts!
All I have to now is figure out why I have 1 driveshaft and 4 pulleys
1 Parts
Matt
Old 03-28-2006, 12:40 PM
I cant help you figure that out, sorry!
Old 03-28-2006, 01:24 PM
freakmech's Avatar
freakmech freakmech is offline
Send a message via AIM to freakmech
You should have 2 driveshafts (axles) and 4 boots, one for each end of the 2 axles. or am i wrong?
Friends dont let friends buy die-casts...
"If it can't run 24hrs., it aint sh!t...." -me
Old 03-28-2006, 01:52 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Maybe these sorts of things are different in Japan?
Stevenski, I do hope you don't run out of little chrome ponies.
Welcome to AF, MattRS2000!
PHOTOBUCKET SUCKS
Old 03-29-2006, 02:06 AM
hirofkd's Avatar
hirofkd hirofkd is offline
You guessed it right.
Kinda make sense, doesn't it?
Hiroaki Fukuda
Old 03-29-2006, 02:31 AM
klutz_100's Avatar
Just checked the pack - there's only one driveshaft~?!?!
Now, just to humiliate myself publically even further - what ARE theys boot-pulley thingys anyway? Where the heck do they go?? On the engine? I can't imagine that thay are for the wheels, but.....
MPWR - ask me again after I start loosing the little critters all over the workshop!!
Old 03-29-2006, 02:48 AM
sjelic's Avatar
sjelic sjelic is offline
Boot is that rubber part that protects joint (homokinetic joint), you have one on the wheel side and one on the gearbox (differential) side.
This should be it
Sasa Jelic
SCALEMAKERS
Old 03-29-2006, 07:17 AM
MPWR's Avatar
Those things you labeled '5'? They're constant velocity (CV) joint boots. One goes on each end of each drive shaft, so they look like this:
Make the extra drive shaft out of whatever round stock you have lying around.
PHOTOBUCKET SUCKS
Old 03-29-2006, 08:11 AM
sjelic's Avatar
They don't say for nothing that picture is worth a thousand words
Sasa Jelic
SCALEMAKERS
Old 03-29-2006, 08:17 AM
klutz_100's Avatar
Hmmm...so where's your 037 I wanna see it!!
So these connect the front wheels to rear wheels, correct?
Old 03-29-2006, 08:56 AM
MPWR's Avatar
Yeah, and the top ones to the bottom ones.
My 037?
PHOTOBUCKET SUCKS
Old 03-29-2006, 09:40 AM
Thanks for the welcome!
There is definitely only 1 driveshaft, it says "ippon" which means 1. I dont know why though....... Good luck!
