Throttle Sticks, Help!
yea guys i cant race now, cuz every once and a while my throttle sticks and it stays at the redline, i have to turn the car off. i pop the hood and mess with the cable (it feels fine) and when i turn the car on its fine, what the hell is going on???? any help PLEASE!!! plz, ima kill a crx and an integra, there saying that i'm pussying out.
frank
'94 3kgt SL -ebay intake (why not) -2 1/2 inch straight pipe exaust, custom y downpipe -Ignition mods -dual magnaflow exaust -going TT (wish me luck) black book -'95 mustang v6 (modded) ///// -'00 neon (modded/non-turbo) /// -'04 eclipse GT -'05 eclipse GT (modded) -'97 Prelude vtec (modded) -CRX (modded) -Mazda Miata mx5 // |
Re: Throttle Sticks, Help!
Check your TPS, it should be the sensor at the top of the gas pedal. When you depress the pedal, you will see a little sensor compress - that is the TPS. It signals the ECU to increase or decrease throttle. The pedal can bounce back, but the TPS may stick. Also check the cable, have someone throttle it up and down while you watch the cable, it may be sticking somewhere.
Yeah, pop the hood and check it out. Once after having my intake manifold off, when I put it all back together, a vacuum hose got stuck under that throttle switch on the throttle body, and caused it to stick wide open. Redline in neutral isn't good.
Also, get some carb cleaner, and just spray it into the throttle body, while opening and closing the butterfly manually. Inspect the butterfly visually and make sure it is opening/closing properly and not being interfered with.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
