Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-27-2006, 04:13 PM
3000gtsl 3000gtsl is offline
Single turbo for 3000gt sl?
Hey i have a 3000gt sl and it has 222hp. I dont know if you can put a single turbo on a 3000gt sl? For example:If you have a 3000gt sl could you put on a 20g turbo on it? I search everywhere but there is no question that is similar to this one. Can somebody answer this if you know?
Old 03-27-2006, 04:24 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Re: Single turbo for 3000gt sl?
You can get single turbos for your SL. I'm not sure who makes them, mabye Greddy? You would probably be better off just doing a twin turbo conversion off of a VR4. Another thing is that your car doesn't have 222hp because it is said that Mitsubishi overrated it although some will beg to differ. I think it has areound 205hp or so.
Check out this link of FAQ's about forced induction for a 3000gt n/a:
http://www.3si.org/forum/archive/index.php/f-53.html
Old 03-27-2006, 04:57 PM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
if you want to make a custom single turbo job, the biggest aspect that you will have to deal with is the fabrication of exhaust manifolds that will come connect before the turbo... good luck
Georgey on the subject of midget beastiality pornos
Originally Posted by 1viadrft
I've seen a video or two out of curiousity.... those damn midgets are hung! But then the donkey walks in...
Home Puta's 4Life Crew Member #1
R.I.P Andy, you will be missed by all.
Old 03-27-2006, 05:24 PM
Igovert500's Avatar
blue + red light magnet
Exactly, that is why most go with the TT route, because they can use many vr4 parts, such as the exhaust manifolds. Otherwise you are going to have to get a set fabricated for your custom setup.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-04-2009, 11:13 PM
farner85's Avatar
farner85 farner85 is offline
need help!!!
hey I want to run all my stock vr4 ecu injecters fuel pump
and make my own tubing for a single turbo conversion.
does any one know what "single turbo" and psi
I should use with out doing any damage to my stock motor?
I only have after market headers. the rest of the car is stock
I can tig weild and fab so thats not a promblem,
Old 02-04-2009, 11:26 PM
Hotshot8792 Hotshot8792 is offline
Originally Posted by farner85
need help!!!
that will all depend on how well you can tune your car. Get a datalogger.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 02-05-2009, 08:17 AM
farner85's Avatar
is there any single turbo that would not need tuning just a stock
vr4 computer/injecters/pump air fuel mix? if so whinch one and how many psi ?
Old 02-05-2009, 09:16 AM
AutostradaVR4 AutostradaVR4 is offline
You would have to look at the turbo specs to try and find one with similar flow characteristics to a pair of 9B's. The problem is the SL has a higher compression ratio than the vr-4, so if you're going to run more than stock vr-4 boost, knock will be an issue. Listen to Hotshot, he has a TT'd SL i believe.
What's the reason you want to go with a single setup vs twins?
EDIT: sorry, got confused between the OP and new poster, just realized you have a VR-4.
You should be able to safely run about 14psi before knock becomes an issue. A single turbo that's equivalant the the 2 9B's? not sure how you figure that out, but i would think you just find one that flows twice the CFM of a 9b? The issue with that is lag.
There's a nice chart on stealth316.com about flow rates and whatnot.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 02-05-2009, 11:57 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Dont bring up 3 year old threads.
Closed Thread
