Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 03-27-2006, 04:15 PM   #1
LikeAChampion3
Replacing the A/C Compressor in 97 Lumina
I previously had a question about changing the water pump in my 97 lumina, now it turns out that the WP was not my problem. I now have to change the A/C Compressor...so I am looking for advice from anyone who might have done this job before on this 3.1 engine. Thanks for the help
LikeAChampion3 is offline   Reply With Quote
Old 03-27-2006, 05:28 PM   #2
richtazz
stupidity should hurt
richtazz's Avatar
Re: Replacing the A/C Compressor in 97 Lumina
It's not fun. It's on the bottom of the front of the engine, and everything is in the way. It will require a recharge of the system, and teh compressor will come without oil, and you need to turn the compressor over by hand a few turns to get oil into the piston before you install it in the car, otherwise, you'll burn it up.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
richtazz is offline   Reply With Quote
Old 03-27-2006, 07:26 PM   #3
maxwedge
A990 racer
If you are changing the compressor for a pulley bearing that is not necessary, I changed my bearing only, what is the problem?
maxwedge is offline   Reply With Quote
Old 03-27-2006, 10:17 PM   #4
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
I've had GM compressors that rumbled for years without ever failing.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
jeffcoslacker is offline   Reply With Quote
Old 03-28-2006, 12:41 AM   #5
LikeAChampion3
Great ...I wish I could just go without this damn AC compressor because I haven't had AC for 2 years anyway. Thank though! I know i can get a compressor for $80 if that is the way i go.
Old 03-28-2006, 12:54 AM   #6
LikeAChampion3
If I could just do that, that would be great! How much $/time is involved with that? Also how easy is it compared to changing the water pump in that same engine? This hopefully will be the route I take
Old 03-28-2006, 12:57 AM   #7
LikeAChampion3
What kind of rumbling do you mean? The sound coming out of mine is a screeching, grinding, terrible sound that is louder than hell. Also, is there a chance that if I just leave it unchanged (bearings and all), that the pully will come loose and throw the belt? By the way thanks for your help with the water pump earlier today! It was as easy as you said it would be
Old 03-28-2006, 01:13 AM   #8
cadgear
cadgear's Avatar
If the bearing is bad and seizes, then you burn up the belt from friction. Not a good thing, to be certain.
You can change the whole compressor yourself, but it won't be fun..unless you're like me and see extra work a good thing when it comes to these kind of things. Could be why I don't have many customers come my way...
cadgear is offline   Reply With Quote
Old 03-28-2006, 08:53 AM   #9
jeffcoslacker
Eek! Yeah, better get rid of it. Does sound like it's just the pulley bearing though, you wouldn't hear the compressor itself if it doesn't work. Yes, it's going to sieze and pop the belt, most likely.
...empty gun rack.
