Old 08-12-2001, 05:37 PM
JE123's Avatar
JE123 JE123 is offline
What do you all use to mask pieces?
On one of my models the body has to be painted two different colors. I usually use masking tape but it is pretty hard to get to fit in some areas. What do you suggest using?
Old 08-12-2001, 05:43 PM
Guiddy's Avatar
Guiddy Guiddy is offline
You must go for Tamiya's masking tape, as it is super sticky and very mallable.
Other than that, you can get a rubbery paint on mask liquid from Revell, but I haven't used it on 1/24 models, only my old 1/10th race car bodies.
For a body you can't deat Tamiya masking tape, go for some of that.
I used it for my 1/24th R34 Race car and it worked a treat.
Old 08-12-2001, 05:47 PM
JE123's Avatar
When you have to paint two different colors which do you paint first? The smaller portion or the larger?
Old 08-12-2001, 05:50 PM
Jay! Jay! is offline
Horizontally Opposed
This is also my current dillema. I'm working on an early NSX, when the roof was black above the windowline no matter the body color.
I did it once with plain old masking tape, and the black paint leaked under, so I have to start over.
This time I think I'll try Tamiya's masking tape like Guiddy said. I've used the liquid stuff in the past, but it's more mess than it's worth.
Hierarchy of Subaru:
(Click to see mine!)
Old 08-12-2001, 05:52 PM
Always paint the lighter color first. For example, I'd never get the red to show up right, even after a thousand coats, if I tried to paint it over the black.
Old 08-12-2001, 05:53 PM
Guiddy's Avatar
The lighter colour first buddy, other wise the dark colour shows underneath!
So for the Skyline I painted the yellow first, then the black.
You must peel the masking tape off as soon as you can, say within 5 minutes, otherwise the tape pulls the paint off with it!!!
Here is another example.
I painted the white first, then masked the ribbon off and the top section. Painted the red, then masked it all off and added the blue.
Old 08-12-2001, 05:54 PM
JE123's Avatar
[quote]Originally posted by Silver S2000
[b]This is also my current dillema. I'm working on an early NSX, when the roof was black above the windowline no matter the body color.
That is exactly what I have to do with my model.
Guiddy's Avatar
Great minds think alike!!!
Old 08-12-2001, 05:57 PM
...Or learn the same lessons from their mistakes.
Old 08-12-2001, 09:32 PM
primera man's Avatar
"P-Man"
Just use Tamiya masking tape to give that nice clean line you want.
View All My Models Here.
Old 08-12-2001, 11:09 PM
JE123's Avatar
What size Tamiya masking tape do you use? I found a site www.hlj.com which has 3 different sizes. The site does not show a picture of them though.
Old 08-12-2001, 11:56 PM
I highly recommend that site. I have ordered from them a couple of times. You pay for shipping, but it may be worth it in some cases.
Where do you live? You may be able to find it somewhere close to you.
Old 08-13-2001, 12:42 AM
"P-Man"
POST NUMBER 1800 !!!!!...IM A POST WHORE
Anyway........go for the 6mm tape. That's all i use. When masking the model, use the 6mm for the line you want then i just use plain old masking tape put about half way to the edge of the line along with newspaper.
Old 08-13-2001, 12:48 AM
You're the post-whore-iest guy around!
And since Kris isn't here, I'll have to pick up the slack:
Old 08-13-2001, 12:55 AM
"P-Man"
THANKYOU
