Old 03-27-2006, 01:36 PM
tonejones tonejones is offline
Talking only one headlight works
I have a 1997 Escort that one headlight stopped working and is not fixed by a new bulb. Any tricks I should be aware of?
Old 03-27-2006, 11:32 PM
KimMG KimMG is offline
AF - Advisor
Re: only one headlight works
fuse (loss of power)
loose ground
Use a test light to check the power supply.
Old 03-28-2006, 06:12 PM
Davescort97 Davescort97 is offline
Escort guy
KimMG is right on the money. The fuse for the headlights is in the engine compartment to the front and right of the battery. I think there is a separate fuse for the left and right headlights. The bulb could be bad even though it is new. Check the continuity with a volt meter. Also, check the power supply at the connector with a volt meter.
