SES light reset procedure?
I know it's been posted before, but I can't find it...
Can someone quickly run through the procedure to turn off the SES light? I ran the code at Autozone so I know what the problem is (I've already changed the plug that was giving me a misfire), but the light is still on --> I have seen a procedure that involved the key in the acc position for x number of seconds, wait, crank, or something... but I can't remember the exact procedure... little help? thanks!
1998 Pontiac Grand Prix GTP 3800 Series II V6 3.5" Supercharger pulley |
Re: SES light reset procedure?
I think the procedure you are referring to is for resetting the change oil soon light. ONly way I know to reset the codes is to clear them with a scanner. Could be that it will reset itself after a set number of cranking cycles after the trbl is cleared.
97 Grand Prix GT 360,000 miles as of 02-01-09 391 000 miles as of 11-17-11 400,000 miles as of 3-15-13 01 Duramax/Allison 07 G6 convertible |
i thought you could clear codes by disconnecting the battery for like 10 minutes or something...
-2002 Grand Prix GT Black
yeah i have herd that disconnecting the battery for like 15 min. will reset it. but if theres still something wrong then it will come back on again of course after a while.
2006 Chevy Cobalt LS |
also would anyone happen to know if theres any type of adaptor or something that exsists where you could plug your home computer in the car computer plug? may sound like a dumb question...
OBDII vehicles require a scan tool to reset the light. It will go off by itself once the problem is fixed after a set number of drive cycles.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
This works on most '97 and up GM "F" and "W" body cars:
Remove battery POSITIVE cable. Take ignition to full on/start position and hold for minimum of 1 minute. Take ignition back to off. However, key will not return to off and will be stuck due to lack of battery power. Reconnect battery positive. Various relays will chatter. Now take key forward then back to off. It should now remove. Re-insert key and start engine. SES should be off unless a Class "A" DTC error code immediately triggers it. This resets any and and all DTC error codes stored and WILL clear a SES light. If it doesn't work then you will need a odb-ii scanner with reset. BTW - If it works don't ask me how or why it does. Good luck!
I've been looking at the AutoTap OBDII software and cable for PC's. Anyone have any experience with this product? The link to their web site is http://www.autotap.com/review.html |
You can monitor key activity like 02 sensor activity, etc. on a virtual gauge display. You can put up several virtual gauges. Plus it will read odb-ii error codes and reset the SES light. Makes you look hi-tech.
