Old 03-27-2006, 12:11 PM
Davidicus Davidicus is offline
Cool Possible alternator porblem. Advice please?
Hello everyone. I recently got an '89 Park Avenue (see my earlier post "need some advice on 89 Park Avenue" link: http://www.automotiveforums.com/vbul...d.php?t=536080) and it runs pretty much fine except about a week after I got it my battery started running low and died shortly after. I tried to leave the car running for a bit to charge it up with the alternator but that didn't make it any better. First the battery light went on and my voltage meter started reading low and then it died on me. I got a new battery this morning and my battery light is still on. I didn't leave the lights on but when i fight got the car a 9 days ago I did sit in it for a while listening to the radio and messing with the seats while it was turned off. I don't know if that contributed to any of the problem since my car died last night and that was 7 or 8 days after I sat in it listening to music. Any advice or knowledge you guys have on the subject would be much appreciated. Any possible problems that you could see or predict? Thanks again everyone.
Old 03-27-2006, 12:56 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Possible alternator porblem. Advice please?
Never try to recharge a battery from a low status with the alternator, the alternator is there merely to restore the charge used for starting and to maintain a constant voltage to the battery while the vehicle is in use.
Anytime a battery falls below the starting threshold (12.20 or less) it should be charged by a cycling system. The strain you put on the alternator may have burned it out. This would very well the case provided that the belt tension is good.
Old 03-27-2006, 07:31 PM
When I tried to "recharge my battery" I just left it running in the driveway for about 10 minutes. So are you saying that I might have hurt my alternator by keeping it running for a while or for letting it run dead like that?
Old 03-27-2006, 09:47 PM
johnd89 johnd89 is offline
right after I got mine, I would park it on the side of the road where road is not level. for some reason instaed of readjusting only three times the rear suspension level, it would deplete the battery...
as a short time solution I would disconect the battery at night.
sure enough, one month later the alt died...
replaced it and wired under the dash a swich from the power wire of the air compressor. now I swich it on whenever I want.
as long as the park is parked level and it dosen't have a leak in the system it shouldn't go on. of course since then I put new rear shocks and I don't have any more leaks (the old rear robber boots tend to crack on the shocks and eventually break...)
my advice is to go to one of those places with both the alt and battery and check them up to see if they are still good. it should be free of charge.
battery/alt are hand in hand, if one dies, it takes the other one with it.
Old 03-28-2006, 09:16 AM
wrightz28's Avatar
If I had to put a percentage value of likelyhood it would be well above 85%
Old 03-28-2006, 09:44 AM
So is the alternator something that i could replace with help from friends or is it a must that I take it in to a shop?
Old 03-28-2006, 11:17 AM
wrightz28's Avatar
You absolutely can do it your self. Shouldn't take more than 10 minutes to do.
Old 03-28-2006, 07:17 PM
Yeah i just disconnect the belt, unplug it and replace it right? Now I don't know much about this stuff but I dont even have to get under this thing to take it out right? Is there any possible complications i could run into by doing it myself? Should i just buy a new alternator or is there any way of fixing my old one? Do you own a Buick as well? I am positive it is the alternator because the battery only goes down when it's running. So what do you think it was that killed my alternator?
Old 03-28-2006, 07:37 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Remember to disconnect the battery before removing the alt! The link below may help you with your problem.
http://www.automotiveforums.com/vbul...amp+alternator
Old 03-28-2006, 09:10 PM
you may want to invest 17$ in a chilton's repair manual for your car.
you will save this amount with the first repair/maintenance work you will do on the car
good luck!
Old 03-28-2006, 09:14 PM
Alright man thanks for the advice. If you have anything else you want to tell me about what might be wrong with it I would appreciate the knowledge. I read your advice about the delcon alt. and the high power battery. My car is an '89 PA and has kind of alot of features. Windows, locks, seats w/ tilt, ac, temp. guage. So do you think I need the 140 alt. with gel diodes and the high power battery? Any other problems you could see that might cause my alternator to burn out or my battery to drain? Thanks for the advice/knowledge/time. -David
Old 03-28-2006, 09:17 PM
good luck!
Chilton's much better than Hanes? Where is the best place to get one?
Old 03-29-2006, 12:07 AM
don't spend your $$$ on very expensive gel batteries, just get a decent one.
I have a no name rebuilded alt as well... maybe I was lucky, but it lasted some 60k miles and still going strong.
check al connections (ground strap, etc) for corrosion as well
as for the manual, I find the chilton's a little better
Old 03-29-2006, 10:13 AM
wrightz28's Avatar
If you forget to disconnect the battery first, don't worry, you will be reminded
But yes, battery, remove belt, carefully disconnect the electrical connections of the alternator. 2 bolts removed and one dead alternotr out. Be careful not to mix the 2 bolts up in orientation. Replace by going backwards of what was said, NOTE, the batter feed connecotr on the back of the alternator is very delicate, there is no need to go nuts tightening it, snug is good.
Yes I own a Buick as well '87 PA almost the same as yours, and sold the wifes 89 Lesabre (same set up as yours) for my Camaro
What killed your alternator? I told you, trying to charge a dead battery with it. Didn't you hear the voltage regulator screaming when the car started?
And yes, a basic manual is a wise investment by far.
Old 03-29-2006, 09:45 PM
when I said I tried to charge my battery with the alternator all i did was leave it running in the driveway for 15 or so minutes. From what I have gathered from reading about this problem what I did was drain my battery by messing with the radio and seats for a while with out it running and all my trips in the car were short trips and quite a few of them. I think then when I left it running it wore on the alt. and then when I got to the pizza place where it died letting the battery run so low that i needed a jump fried the diodes (whatever those are) in my alt. Does that seem about right to you? Also, is there any way that I could mess somehting up when putting in my new alternator save from not removing the battery lol? what brand do you recomend?
