Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 03-27-2006, 10:34 AM
T66's Avatar
T66 T66 is offline
BOV Question
Guys, will my turbo go to wrack and ruin when I remove the BOV? Boosting 8psi.
English is not my first Language.
Old 03-27-2006, 11:42 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: BOV Question
If you remove the BOV, you wont be boosting at all and your car will run like absolute junk, now that youve got a huge intake leak.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 03-27-2006, 02:44 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
Re: BOV Question
if you seal the intake when you remove it you run the risk of hurting your turbocharger. why do you want to remove it anyways?
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them.
Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood.
On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear.
Old 03-29-2006, 11:56 PM
UncleBob UncleBob is offline
AF -Advisor
Re: BOV Question
at 8psi, you won't hurt anything.
BOV's are most effective on high-boost engines. Low boost over many many many miles, will see a very slight change in turbo longevity without a BOV, but its decimals. Look at all the stock turbo cars that didn't come with BOV's over the last 20 years, and had turbo's live 100+K miles.
Old 03-30-2006, 10:46 AM
Re: BOV Question
thats because they used bypass valves instead. Seriously, not running a BOV or bypass valve is bad news.
"The CEG Nazi"
www.contour.org
Old 03-30-2006, 12:31 PM
Re: BOV Question
just a question, why do you want to remove your BOV?
Old 03-30-2006, 02:21 PM
534BC 534BC is offline
Re: BOV Question
It depends on the application, if it is sized such that will overboost without a valave then that is exactly what will happen. I imagine that is true if it has a bov on it and will hurt engine before hurting turbo most probably.
Old 03-30-2006, 05:37 PM
Re: BOV Question
what you're thinking of is a wastegate. a wastegate opens to let out exhaust gases so you don't overboost. a bov (blow off valve) vents boost from the intake into the atmosphere so that the turbo isn't hurt when the throttle valve closes because that sends a pressure wave back at the turbo and it can surge.
Old 03-30-2006, 05:59 PM
Re: BOV Question
Ok, I got it. My mistake. We used to use that also to control max boost also. What would a typical set point be for a 10 pound system?
Old 03-31-2006, 09:13 AM
Re: BOV Question
a 10 lb spring.
"The CEG Nazi"
www.contour.org
Old 03-31-2006, 05:34 PM
Black Lotus's Avatar
Black Lotus Black Lotus is offline
Re: BOV Question
Try adjusting it so it just cracks open at maybe, 6 PSI.
That's just a starting point, so watch out for under/overboost.
Old 03-31-2006, 06:39 PM
Re: BOV Question
I'll rephrase question. If I want to push 10 pounds of boost what should the setpoint or cracking pressure of a bov be?
If the cracking point of a bov is below the amount of boost then we are losing pressure, that sounds typical of some of the small diameter valves I used in the past. It makes for slower boost building.
If I understand what the bov is for (keeping the high pressure from backing up into turbine during shifts or during quick throttle letoff) then it would seem to set the blow off point at some setting higher than the highest boost attained.
How does that sound?
Old 03-31-2006, 08:13 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: BOV Question
The problem there is that you're trying to do two completely different jobs with one type of shift valve. You should do it right with a wastegate and a possibly a boost controller.
Anyhow, at any PSI you can damage the turbo’s bearings if you remove the BOV. The intake charge will move back into the compressor blades causing them to shudder and damage the bearing. Granted the lower the PSI the less damage you can cause. However, at high boost you can break off compressor blades. At lower boost, like 8 PSI, you're causing damage to the bearings.
Leave it on.
Old 04-02-2006, 11:58 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: BOV Question
Originally Posted by Polygon
Leave it on.
I couldn't agree more....compressor surge isnt a good thing and if its severe enough, it could slow spool time slightly
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
