Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 03-26-2006, 11:04 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Control Arms
Hey guys, after installing my motor mounts I found that my control arm on the drivers side is FUBAR. My car was made Dec. 1999, and I guess it is different than later model years, and I have not been able to locate a stock or aftermarket control arm for my car anywhere. Just curious if you guys knew anyplace that sold them. Also, Do our cars have an Upper control arm? Any help with be much appriciated.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 03-26-2006, 11:39 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: Control Arms
wow, that sux!! good luck finding it, club3g might be a good place to look w/ fed specs getting parted out periodically...
Don't act like you don't love it.
503/2000
Old 04-23-2006, 11:18 PM
rodbls's Avatar
Re: Control Arms
Well I finally ended up just going to the dealer because every shop I went to said it would be impossible to get it otherwise. Actually not too bad on the price (160 a side, and other years online were around 140 so not too bad since it was at a dealer). Hopefully it goes in with little trouble.
Old 04-24-2006, 12:31 AM
Sleepr awd's Avatar
Re: Control Arms
good luck on the install, control arms are difficult, cuz you can't tell if they are any good unless they are new.
didn't look to hard from when i took it all apart though, maybe a breaker bar and basic ratchets will do it, and then an alignment after you are done
503/2000
Old 04-24-2006, 03:53 PM
rodbls's Avatar
Re: Control Arms
yeah, they are new OEM so they had damn well better be good. Install didnt look too bad either, except getting the ball joint in and out...ill post after i get it done to let anyone else know how bad it was and any tips.
Old 05-04-2006, 11:44 PM
rodbls's Avatar
Re: Control Arms
I just wanted to say that I got my control arms put in no problem. I did it by myself and with an Impact wrench and a floor jack I was able to do it easy in about an hour and a half. So, if you need new control arms, DIY because its cake. Even if you dont have pneumatic tools you could do it with a littl muscle.
