Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-26-2006, 05:50 PM
rontomed's Avatar
rontomed rontomed is offline
Question Backup Lights Switch Adjust
While backing I have to raise up on the automatic column gear shift slightly for the backup lights to come on. I need advice on how to adjust the backup light switch. Is it at the automatic transmission or on the column gear shifter? This is a 1999 Dodge Ram 1500 with a 5.2L engine.
Old 03-26-2006, 11:04 PM
sneakybert sneakybert is offline
Re: Backup Lights Switch Adjust
The ajustment is on the shift linkage, you will need a 1/2" wrench to adjust.
Old 03-27-2006, 12:24 AM
rontomed's Avatar
Is it the linkage at the column gear shifter or at the transmission?
Old 03-27-2006, 10:35 AM
You access the adjuster from underneath. Behind the splash shield on the left front wheel.
Old 03-30-2006, 08:51 AM
edbrycem edbrycem is offline
I did this recently and its easy BUT its touchy. I adjusted the correct way, my reverse lights stayed on, but it took a little mor pressure to put in park.So I tapped it back about 1/8 of an inch and it goes it par good, but lights shutoff again. Try tapping it back about 1/16 of an inch. ha ha, ya right......needless to say, I have to hold up my shifter to keep my lights on, at least it was a nice day out to lay on my back and waste time.LOL
