Old 07-08-2002, 10:56 PM
5_LiTeR_EaTeR 5_LiTeR_EaTeR is offline
Send a message via AIM to 5_LiTeR_EaTeR
Clutch not making vtec work!?
Well I finally got to work on my car today because my vtec stopped working again. I replaced my old VSS off my old D-Series but was wondering if it could be my clutch. I replaced my Clutch for a 90 integra. Was that what I was suppose to use because I think it didn't come with vtec that year and maybe theres a reluctor ring in the clutch that the VSS reads off of but I could be wrong. Also I know that there is a mechnical VSS and a Electronic VSS but does it make a difference? Its a b16 in a CRX. The VSS I have you can push the tip and it will spring back out so I'm thinking thats the mechanical one. My vtec worked for about 3 months then quit. Someone help me out thanks! I KNOW MOPPIE CAN!!
VTEC WORKING FINALLY & HAULIN SOME ASS!!
If the shadow of your car is smokin' you it definately means you are smokin' someone else!!
KKK k24 Turbo on the way to the install!
Old 07-16-2002, 03:11 PM
stefan525 stefan525 is offline
Send a message via AIM to stefan525
well I don't think your clutch has anything to do with your VTEC. your VTEC engages at a set RPM, when your car reaches a set MPH and only when the oil pressure is right. So if you have a problem with your VTEC you should check one of these three. Or you might have a bad VTEC selenoid.sp. Good luck. stefan525
PS: check your oil, VTEC wires, VTEC selenoid, oil pressure sensor, speedo cable/sensor. thats all I could think of right of the top of my head.
Old 07-16-2002, 04:32 PM
Vtec engages off oil pressure, the right RPM and temperature and also the VSS (vehicle speed Sensor). I am getting code 17 which is VSS. The VSS is a pulse oscillator and reads with every pulse from the tranny while in movement. I just dunno if it gets its reading off a reluctor ring on the clutch or whatever because I did get it for a 90 Integra and thats a b17 non Vtec. If the vtec solenoid was bad it would throw code 21 meaning bad Vtec solenoid but it isn't that. Oh well I started my car after summer school today ran for 1 sec then died. It jumped timing and bent all the intake valves because honda motors are interference motors. Now I gotta take the head off replace the valves and timing belt also the water pump. Anything else I should do while its off?
Old 07-16-2002, 10:40 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
The VSS reads off the Crown wheel on the Diff.
So the clutch that you use has absolutly no effect on it.
I would go and take mine out and have a look at the end of it for you, but its not eactly easy to get to.
Old 07-17-2002, 04:41 PM
Thanks thats all I wanted to know. I lucked out once again. The timing belt was in perfect condition just jumped teeth. I thought I bent some valves but I didn't. Must have jumped a certain way where it would crank over with no compression so I am guessing the intake valves were open when the piston came back up and throwing all compression back out the intake. So I took my head off today, took me 1 1/2 hours to do, Head gasket set is gonna cost me 200 damn dollars.... list is 305 so I guess I'm okay. I also found out why the timing jumped. MY DIZZY FROZE UP AGAIN! I think it froze because lack of oil going to it. I saw a hole in the cameshaft and it feeds the dizzy. Either I have a blockage in an oil passage to the dizzy like in the camshaft or I am running low on oil. I was 2 mm above the bottom dot on the dip stick when I checked so I dont know... Does this sound correct? Oh yeah do they make rebuild kits for dizzys? I didn't ruin anything this time I just froze a bearing up.
Old 07-31-2002, 07:19 PM
civicsir1990 civicsir1990 is offline
it's happen with mine and the knock sensor are disconnected when i plug in place the vtec come again.Thanks god.Good luck
rusty but fast
