Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-26-2006, 04:38 PM
player11 player11 is offline
Intake Manifold Gaskets Covered?
Have a 2002 Rodeo. IMG were replaced last March..I'm having the same problem again it appears..sometimes stalls right after start up, CEL on most of the time. Work was covered last March as I was within 3 years. Looking at warranty book today and I see the 2002 has a 10 year powertrain warranty and seals and gaskets are listed as covered parts...SO, intake manifold gaskets are covered under powertrain warranty?
Old 03-26-2006, 07:04 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Intake Manifold Gaskets Covered?
they are covered for the 1st owner for 10yr 120k.
the second ower it is covered for 5yr 60k.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 03-26-2006, 07:09 PM
Does it makes sense that the IMG would need replacing when just replaced a year ago? I've also read that the EGR might be the problem..can you tell me the differences between the teo? I have occasionally stalling right after start up, CEL mostly on solid, sometimes flashing..other times it's off.
Old 03-26-2006, 07:35 PM
marcre's Avatar
marcre marcre is offline
Send a message via AIM to marcre Send a message via MSN to marcre Send a message via Yahoo to marcre Send a message via Skype™ to marcre
what code are you getting from the CEL?
If it's flashing you should get it looked at quick. A bad IMG can give a misfire code, mine did.
marc
2007 VW Jetta 2.5 5sp
1999 Rodeo LS 3.2 4x4 SOLD, but not forgotten
My Rodeo
Old 03-26-2006, 07:38 PM
Isuzu Guy
Yup, need the codes.
And yup it could be the IMG again. i know of one Trooper owner that had his replace (under warranty), twice in one year.
It can go bad due to improper torque on the bolts.
Autozone will read the codes for free.
-Ryan
Isuzu Moderator
Car Show Tips
Old 03-27-2006, 02:51 PM
OK..had the codes read at auto zone and they were 171, 174(system too lean, banks 1, 2) and 300- Random/multile cyclinder misfire
Does this sound like IMG? Again 2002 Rodeo, 48k miles, had IMG replaced last year. Only symptom is occasional stalling right after start up. Besided that, seems to run fine and idle fine as well.
I don't want to take it to a dealer unless it's the IMG(covered under powertrain) Anything else and I wil take to local mechanic.
I'm assuming the 300 code could also cause the 171, 174?
Old 03-27-2006, 02:59 PM
marcre's Avatar
those codes show up with a bad IMG. To me, it looks like that is your problem. I'd get it looked at soon. It may turn out to be something different, but all signs point to an IMG.
My Rodeo
Old 03-27-2006, 03:22 PM
Isuzu Guy
yup, what he said:
-Ryan
Isuzu Moderator
Car Show Tips
