Old 03-26-2006, 03:33 PM
usmailman956 usmailman956 is offline
Exclamation 01 voyager blower motor
Does anyone know the procedure for replacing the blower motor. I have replaced the resistor 4 times since last sept and it blew again yesterday. I was told blower motor reisistance would cause this to happen. It gets closer everytime I replace it.
Old 03-29-2006, 12:40 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 01 voyager blower motor
I did it on a 96 a while back. Disconnect the battery so you don't blow an airbag. Remove the glove box. You should now see the roundish blower motor housing. Remove the 4 screws on the black plastic case and remove. Remove the 3 or 4 bolts that secure the motor. Lower the motor and disconnect the connector. I would spend the 15 -20$ for a manual that tells you everything you need to know first.
Old 03-30-2006, 05:07 AM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Check the connector that attaches to the resistor, they are known to corrode also.
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
