Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 03-26-2006, 02:42 PM
Hotshot8792 Hotshot8792 is offline
Spark Plug Replacement
I need to replace my spark plugs on my 98 4.0 Liter. I'm not very familiar with these engines just yet, but after looking at it, it looks like I will have to take the a/c compressor out of place to replace them. If so which one of the pulleys is the a/c belt tensioner pulley? I'm just trying to find everything before i start on it. It looks pretty simple after that. Is there any easier way or do i need to remove the a/c compressor? Thanks
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 03-26-2006, 11:02 PM
DwightRGV DwightRGV is offline
Re: Spark Plug Replacement
I also have a 98 TJ and have replaced my plugs a few times. You can get them all out without taking anything apart, but you do need to use an extention and universal joint to get to some of them.
Old 03-27-2006, 09:33 AM
thanks so much for that advice, that will definitely save me a lot of time instead of taking everything apart. I do have plenty of extensions and a universal joint.
One more question as well, is there any other regular maintenance that is needed with these cars? Like, for example, on mitsubishi's, the timing belts and water pumps have to be replaced every 60K miles. Thanks again.
Old 03-27-2006, 01:35 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
Jeeps need:
Coolant: 30k
Oil: 5k
diffs: 10k
air filter: 10k
lube suspension: every oil change
Mud: every chance you get
1995 Jeep Wrangler
3 1/2" lift 33x12.50 tires
4.5L stroked I-6
Bored throttle body & Cold Air Intake
Jet Chip Stage 2
Jet Thermostat
Colorado Off Road Rig!!!
Old 09-28-2007, 06:01 PM
jds1vette jds1vette is offline
Anyone know a quick way to replace the #1 plug on the 2.5 with a/c? That thing is buried.
Update..Just took off the Intake crossover and used an extension with universal. Pretty sure they were original plugs. They had worn to a
.050 gap. 83K miles.
